Page 45 of 109
Re: PhotonGI cache
Posted: Mon Feb 18, 2019 7:38 pm
lacilaci wrote: Mon Feb 18, 2019 6:48 pm
btw regarding caustics, do you think that you could cache reflective caustics too? Maybe bellow certain roughness, opposite of indirect cache...
What do you mean exactly with reflective caustics ? What is the difference with normal caustics ?
Re: PhotonGI cache
Posted: Mon Feb 18, 2019 7:47 pm
Dade wrote: Mon Feb 18, 2019 7:38 pm
Well I guess the normal caustics are the specular ones, like through glass etc and I call the reflected ones the ones from highly reflective material, metals etc when no clamping is applied. Atm the caustic cache works with specular materials only, no?
Re: PhotonGI cache
Posted: Mon Feb 18, 2019 9:18 pm
lacilaci wrote: Mon Feb 18, 2019 7:47 pm
Like I disable indirect cache for glossiness under 0.2, I could enable caustic cache in the same situation
However be aware that caustic cache is a lot more complex, slower, etc. to use than indirect cache (because it is seen directly).
Yes, at the moment.
Re: PhotonGI cache
Posted: Tue Feb 19, 2019 11:55 am
I added the support for caustic cache to OpenCL code.
Re: PhotonGI cache
Posted: Tue Feb 19, 2019 2:31 pm
by Racleborg
Thanks. Awesome!
Re: PhotonGI cache
Posted: Tue Feb 19, 2019 3:07 pm
by marcatore
Cache filtering is a setting that needs an update to the Blender Addon?
Re: PhotonGI cache
Posted: Tue Feb 19, 2019 3:11 pm
marcatore wrote: Tue Feb 19, 2019 3:07 pm
It has not yet been added to BlendLuxCore but the default value will enable it if you update the binaries.
Re: PhotonGI cache
Posted: Tue Feb 19, 2019 4:13 pm
PhotonGI indirect cache now supports all not TRANSMIT and not SPECULAR materials (i.e. metal2, cloth, mix, glossycoatting, etc.).
Re: PhotonGI cache
Posted: Tue Feb 19, 2019 5:22 pm
Dade wrote: Tue Feb 19, 2019 4:13 pm
That was quick, will try on thursday. Now shooting wedding
Re: PhotonGI cache
Posted: Wed Feb 20, 2019 2:27 am
by frank_yifei
For a test scene, I tried to make the caustic result look smoother so I increase lookup radius. I found a problem.
using opencl + photonGI, setting caustic lookup radius higher will crash blender. The error message is "ERROR: clEnqueueWriteBuffer
Error: Unrecognized Exception". Path cpu works well with caustic, i can set lookup radius to any value, like 100.
Indirect cache can have lookup radius at any value, under opencl or cpu
My computer have 4 core intel cpu, nvidia 1060 6gb.
