Page 5 of 32
Re: OpenImageDenoise
Posted: Thu Jan 31, 2019 1:20 pm
by alpistinho
acasta69 wrote: Thu Jan 31, 2019 1:01 pm
alpistinho wrote: Thu Jan 31, 2019 11:57 am
Maybe that's better than what I am doing. I think this library uses Intel MKL, so that would be another dependency. I will try to compile against the binary later today when I am home.
By the way: which platform are you working on?
Linux Mint 18.3 (Ubuntu 16.04)
Posted: Thu Jan 31, 2019 5:42 pm
Like with Intel Embree, we can just use their binaries. I usually include the sources of small libraries without binaries available for Windows, Linux and MacOS.
I can add the support for albedo AOV tomorrow ... today I was skiing
Posted: Thu Jan 31, 2019 7:59 pm
Dade wrote: Thu Jan 31, 2019 5:42 pm
oh, that's one less problem to worry about then
Posted: Thu Jan 31, 2019 9:58 pm
by alpistinho
Just an update: Both Embree and OIDN include a copy of libtbbmalloc.so.2, but they are not the same. They're probably compiled against different versions of TBB.
I need now to find a way to include both and link everything correctly
Posted: Thu Jan 31, 2019 10:47 pm
alpistinho wrote: Thu Jan 31, 2019 9:58 pm
The newest is likely to work fine for both
P.S. just try one, than the other ... it may/should work.
Posted: Thu Jan 31, 2019 11:23 pm
by alpistinho
I've tried to compile OIDN following their instructions but it is not working either. I don't know if something is messed up with my system.
I will try to compile against the binary and use the same shared library for both. Sorry for my rusty building abilities
daniel@daniel-desktop ~/Documents/oidn/build $ make
[ 1%] Building CXX object common/CMakeFiles/common.dir/tasking.cpp.o
/home/daniel/Documents/oidn/common/tasking.cpp:45:34: error: no member named 'this_task_arena' in namespace 'tbb'; did you mean 'task_arena'?
const int threadIndex = tbb::this_task_arena::current_thread_index();
task_arena
/usr/include/tbb/task_arena.h:264:19: note: 'task_arena' declared here
using interface7::task_arena;
/home/daniel/Documents/oidn/common/tasking.cpp:51:34: error: no member named 'this_task_arena' in namespace 'tbb'; did you mean 'task_arena'?
task_arena
Posted: Fri Feb 01, 2019 3:52 pm
So, just as nvidia's denoiser. It is absolutely blind to bidir noise.
However, I wonder since it's open source if someone could create and train dataset for bidir as well? Maybe like a mode switch of the denoiser that's autoselected depending on selected renderer(bidir/path-oclpath)?
I don't care about bidir at all, but maybe for future development, to get rid of that... thing completely.
Posted: Fri Feb 01, 2019 4:11 pm
I added the support for Albedo AOV to all CPU path tracers. This rendering:
Has this Albedo AOV:
Next OpenCL and BiDir support.
Posted: Fri Feb 01, 2019 4:21 pm
Looks good to me, have to test with oidn...
But... you said cpu pathtracers, ocl won't output this aov?
Posted: Fri Feb 01, 2019 4:23 pm
lacilaci wrote: Fri Feb 01, 2019 4:21 pm
Not yet, I have still to write the OpenCL and BiDir support.
