In the scene I have to radiance groups.
In the first approach I define 2 image pipelines. In first one I enable radiance group 0 and disable 1. In second pipeline 0 is disabled 1 is enabled
film.imagepipelines.1.0.type = "NOP"
film.imagepipelines.1.radiancescales.0.enabled = 1
film.imagepipelines.1.radiancescales.0.globalscale = 1
film.imagepipelines.1.radiancescales.0.rgbscale = 1 1 1
film.imagepipelines.1.radiancescales.1.enabled = 0
film.outputs.5.type = "RGB_IMAGEPIPELINE"
film.outputs.5.filename = "/home/node/matadorNode/tmp/0_FI_68803_271618_0000_multilight_0.exr"
film.outputs.5.index = 1
film.imagepipelines.2.0.type = "NOP"
film.imagepipelines.2.radiancescales.0.enabled = 0
film.imagepipelines.2.radiancescales.1.enabled = 1
film.imagepipelines.2.radiancescales.1.globalscale = 1
film.imagepipelines.2.radiancescales.1.rgbscale = 1 1 1
film.outputs.6.type = "RGB_IMAGEPIPELINE"
film.outputs.6.filename = "/home/node/matadorNode/tmp/0_FI_68803_271618_0000_multilight_1.exr"Code: Select all
film.outputs.6.index = 2
film.outputs.7.type = "RADIANCE_GROUP"
film.outputs.7.filename = "/home/node/matadorNode/tmp/0_FI_68803_271618_0000_radiance_group_0.exr"
film.outputs.7.id = 0
film.outputs.8.type = "RADIANCE_GROUP"
film.outputs.8.filename = "/home/node/matadorNode/tmp/0_FI_68803_271618_0000_radiance_group_1.exr"
Why I wan to do this? If I merge this 2 images written by image pipelines I get the same result as render output. If I merge 2 radiance groups, I get something different.
