Page 5 of 5
Re: TwoSided material
Posted: Wed Sep 30, 2020 8:03 am
by CodeHD
Does the object have a negative scale in Y direction?
Normals won't show flipped in edit mode unless you apply the scale.
Posted: Wed Sep 30, 2020 8:46 am
CodeHD wrote: Wed Sep 30, 2020 8:03 am
It is the reason I asked if it is instanced, a negative transformation can change the handiness of the transformation (from right to left hand and vice versa) and flip normals.
Posted: Wed Sep 30, 2020 4:42 pm
by CEROE
You have taught me something! The object was negative in the X direction. Once the scale was applied the normals flipped.
It's interesting to see how Cycles and Lux materials treat this scenario differently. Cycles materials leave the normals direction until the scale is applied, while Lux materials treats the normals as if the scale was already applied.
Posted: Wed Sep 30, 2020 8:00 pm
CEROE wrote: Wed Sep 30, 2020 4:42 pm
I would call it a Cycles bug: as proof, having two different results if the scale is applied or not, it is intuitively wrong. It is a common mistake, the transformation handiness swap is tricky to handle correctly (i.e. I have done the same mistake but I have fixed it sometime ago).
Posted: Wed Sep 30, 2020 9:00 pm
by CEROE
Thank you for taking the time to educate me on this!
BTW: I'm the person who contacted you about the PolarGrid project many months back. After a creative hiatus, I'm back on the project again.
Posted: Sun Nov 15, 2020 11:10 pm
by Phantom107
Many thanks for adding the TwoSided material as my usecase is now possible in LuxCoreRender! I'll be supporting
