Re: nakaging capsule
Posted: Mon Feb 05, 2018 5:05 pm
I see that the problem continue. i hope you can see the difference with the noisy output. btw my glossy was a really rough with bump on it.
I've downloaded it and I have a question: is it correct that the scene has materials assigned but the node tree is empty?Sharlybg wrote: Mon Feb 05, 2018 12:54 pm Ok this is it. a bit heavy.
https://drive.google.com/open?id=1-3ep7 ... bmTZsapP0a
show a screenshot. this way we can have better idea.marcatore wrote: Tue Feb 06, 2018 8:18 amI've downloaded it and I have a question: is it correct that the scene has materials assigned but the node tree is empty?Sharlybg wrote: Mon Feb 05, 2018 12:54 pm Ok this is it. a bit heavy.
Like i forget to pack external data into blend file. but don't worry the final project files is intended to be release as a free Luxcore example scene.
Make sure you are using 2.79a Release Candidate or (on Linux) a recent buildbot build.marcatore wrote: Tue Feb 06, 2018 8:18 am is it correct that the scene has materials assigned but the node tree is empty?
Nice to hear... but...Sharlybg wrote: Tue Feb 06, 2018 11:30 am Like i forget to pack external data into blend file. but don't worry the final project files is intended to be release as a free Luxcore example scene.![]()
... I made a mistake. I ran the 2.78...with 2.79rc it's working.B.Y.O.B. wrote: Tue Feb 06, 2018 11:52 am Make sure you are using 2.79a Release Candidate or (on Linux) a recent buildbot build.
https://github.com/LuxCoreRender/BlendLuxCore/issues/12
