Page 5 of 8
Re: Shadow Terminator problem
Posted: Sat Aug 10, 2019 8:07 pm
lacilaci wrote: Sat Aug 10, 2019 6:26 pm So do we know why are these dark patches and how to fix that?
I wonder how is it that other renderers don't suffer from this. Maybe some dirty tricks to limit normals or bump strenght?
Just put a value of 10 (or whatever other huge value) in Cycles bump node strength and you will get some really dark rendering too.
Posted: Sat Aug 10, 2019 8:43 pm
by provisory
I made some tests today, and found that in your case the noise from the jpeg artifacts causes issues.
You shouldn't use jpeg for bump mapping.
Your dirtmap.jpg looked like crap with displacement modifier too (on a highly subdivided plane).
Posted: Sat Aug 10, 2019 8:57 pm
I remember trying different values on cycles and it never looked as wrong as in luxcore, but I might try do some comparisons tomorrow.
well that's all nice, but how come cycles doesn't look as wrong if that's the case?
I don't even know how to respond to that amazing advice...
Posted: Sat Aug 10, 2019 9:39 pm
Dade wrote: Sat Aug 10, 2019 6:14 pm
kintuX wrote: Sat Aug 10, 2019 4:54 pm
Dade wrote: Sat Aug 10, 2019 3:38 pm I decoupled the UV scale and strength, so changing the UV scale doesn't affect bump mapping strength anymore.
Terminator tamed :D Looks nice.
But is it known that Caustics & Bump don't work well together?
The "taming" is currently limited to DIFFUSE and GLOSSY materials: https://github.com/LuxCoreRender/LuxCor ... f.cpp#L243
I haven't yet tried how it works with SPECULAR materials.
Yes, i've noticed that nothing is happening with the glass. But slowly we're getting there 8-)
Yet now, with low poly geo shading, i see different issues will start to occur... like: "What is that edge darkening doing here?" (on the red cone)
Answer: Add edges. ;)
PS
Further info about the "render not stopping" bug:
- Also happens with Azure latest build.
- It's exclusive to OCL.
- Depends on the render size and how long you render before stopping.
With smaller size and shorter halt time more renders can be done before it freezes.
- And on rare occasion, water can get darker.
Steps to reproduce:
1. Press Render.
2. Let it render for more than 30s then Cancel (Esc).
3. Freeze
Blend file:
FreezeBugLC223.blend
(913.38 KiB) Downloaded 1451 times
Nvidia GTX 1070, Driver 430.86, on W10
Posted: Sun Aug 11, 2019 6:35 am
Ok, so here we go last attempt:
cycles no bump:
luxcore no bump:
close, and both look correct right? No problem here.
now bump map, this time I have used procedural and tried to match bump intensities so that visibly both surfaces look bumpy in a similar way.
luxcore bump mapping:
cycles bump mapping:
Can you see why this is a big problem for me? Can you see the unrealistic black outline all over the luxcore scene? And this is super weak bump mapping effect.
scene:
bumpproblemscene_procedural.blend
(4.45 MiB) Downloaded 1427 times
Posted: Sun Aug 11, 2019 6:39 am
kintuX wrote: Sat Aug 10, 2019 9:39 pm
PS
Steps to reproduce:
1. Press Render.
3. Freeze
Blend file: FreezeBugLC223.blend
this problem is related to caustic cache I complained about it a week ago here: viewtopic.php?f=4&t=1271
if you disable the caustic cache everything works ok
Posted: Sun Aug 11, 2019 8:53 am
lacilaci wrote: Sun Aug 11, 2019 6:35 am Ok, so here we go last attempt:
cycles no bump:
luxcore no bump:
scene:
In my opinion Cycles bumped image looks wrong. If you add bump then you get brighter and darker areas compared to original. For axample if the bump is made from an equal distributed half sphere array there is a shadow and a sun part and parts with shades between them. If render is clamped to some max brightness sun parts may have the same brightness as original picture but shadow parts are darker than original picture. The bumped image gets overall darker than the original picture. If brightness is not limited bumped and original image should have similar overall brightness.
Posted: Sun Aug 11, 2019 9:07 am
FarbigeWelt wrote: Sun Aug 11, 2019 8:53 am
cycles no bump:
luxcore no bump:
scene:
Maybe, maybe technically there is something wrong on bump mapping of cycles too, I have no idea and there are times where I really don't like how it behaves on some materials. But take a look at the pictures and tell me the luxcore image looks actually realistic.
Do I need to start making comparisons to photography? Or do you maybe have a white bumpy/rough surface in reality that turns black at glancing angles? If you stand next to a white painted rough surface wall does it turn black? Paint a ball with white paint and put it outside and tell me it turns black at grazing angles.
Even if this is not technically a bug it needs a treatment just as shadow terminator needed it.
Posted: Sun Aug 11, 2019 9:19 am
here is some corona material with strong bump
Posted: Sun Aug 11, 2019 9:27 am
by provisory
After some comparisons I think again, that something is not perfect with LuxCore bump mapping.
Left side is highly subdivided and has displacement modifier with the bump texture.
Right side is low poly and has bump mapping with the same bump texture.
Cycles:
LuxCore after shadow terminator taming:
LuxCore before it:
