Page 5 of 13
Re: Disney BRDF material
Posted: Thu Jun 06, 2019 3:21 pm
epilectrolytics wrote: Thu Jun 06, 2019 3:07 pm
I was not able to tweak the parameters so that both look the same, roughness works totally different between the two.
This is intended, the disney shader uses a more artist-friendly roughness (I like it a lot).
But you can convert between the two:
Posted: Thu Jun 06, 2019 3:29 pm
by epilectrolytics
Thanks for the tip, this will help with converting old glossy to new Disney materials!
Posted: Thu Jun 06, 2019 4:41 pm
How much different is it from luxcore materials, in laymans terms do we "loose realistic look" with this?
I'm kinda getting used to luxcore materials, though I would appreciate a monster ubermaterial that can go from glass to metal to plastic to paper or leaf with handful of sliders.
Posted: Fri Jun 07, 2019 10:16 am
by epilectrolytics
lacilaci wrote: Thu Jun 06, 2019 4:41 pm
I'd say it looks slightly better, theoretically it should because of GGX microfacet model and other goodies,
but you should test yourself now that it is accessible from Blender (latest master).
Posted: Fri Jun 07, 2019 2:18 pm
by sarmath
Hi there. Just updated to latest builds but cant see Disney material exposed anywhere? Any ideas why?
Posted: Fri Jun 07, 2019 2:24 pm
Side note
There is a theoretical advantage in using disney BRDF for all materials in a scene when rendering on GPUs: lack of threads divergence. In theory GPUs while evaluate a lot faster a scene where each hit point requires to run the same material code (threads can run the code in parallel instead of having to serialize the execution of divergent code).
It would be interesting to do some test with a scene using many LuxCore materials and the same scene using only the LuxCore Disney material to check if there is a real advantage on GPUs or not.
sarmath wrote: Fri Jun 07, 2019 2:18 pm
You need also to update BlendLuxCore, have you ?
Posted: Fri Jun 07, 2019 2:25 pm
Dade wrote: Fri Jun 07, 2019 2:24 pm
This:
https://wiki.luxcorerender.org/BlendLux ... _to_Update
Posted: Fri Jun 07, 2019 2:30 pm
by marcatore
Side note
Interesting...it could be a win win situation...
Posted: Fri Jun 07, 2019 2:46 pm
by epilectrolytics
I think that will only install the latest beta but not the latest commits.
B.Y.O.B. said there is a special Blender 2.79 maintenance branch in which the Disney shader is exposed.
This has to be opened in Github and downloaded from there, then used to manually overwrite the Blender add-on files on the user's harddisk before putting the latest LuxCore files in the bin directory there.
