Page 5 of 31
Posted: Sun May 26, 2019 3:10 pm
This is looking really nice, won't it fall apart with more complex situation/obstacles? Is it fully automated solution?
Posted: Sun May 26, 2019 3:23 pm
lacilaci wrote: Sun May 26, 2019 3:10 pm
I don't know, there are millions of possible combinations to tests.
Yes, you can control the resolution of the visibility maps to use more/less memory (and have more/less accurate maps) but it is pretty much automated.
Posted: Sun May 26, 2019 10:20 pm
Bravo this look really like the kind of improvement provided by PGI impressive.
Do the current state work with other light type ? Or it is only HDRi.
And at tje end can this replace DLSC ?
Posted: Mon May 27, 2019 9:20 am
Prominent results, but how does it behave with small opening/s (ie. Camera Obscura or 2-3 small window size openings)?
Posted: Mon May 27, 2019 10:24 am
kintuX wrote: Mon May 27, 2019 9:20 am
guessing at how fast it is on open scene i think small openning will be even faster
can't wait to test it .
Posted: Mon May 27, 2019 11:50 am
Will this cache go through glass or translucent materials? Can I benefit from this when I have huge curtain covering windows?
Posted: Mon May 27, 2019 11:53 am
I have merged the experimental branch with the main one. This feature will be available on daily build now on (CPU-only, OpenCL still to do).
The new cache is available for infinitelight, constantinfinite and sky2 light sources. The related properties are:
scene.lights.<light source name>.visibilitymapcache.enable = 1
scene.lights.<light source name>.visibilitymapcache.map.width = 128
scene.lights.<light source name>.visibilitymapcache.map.height = 64
scene.lights.<light source name>.visibilitymapcache.map.samplecount = 4
scene.lights.<light source name>.visibilitymapcache.map.sampleupperhemisphereonly = 0
scene.lights.<light source name>.visibilitymapcache.visibility.maxsamplecount = 1048576
scene.lights.<light source name>.visibilitymapcache.visibility.maxdepth = 4
scene.lights.<light source name>.visibilitymapcache.visibility.targethitrate = 0.99
scene.lights.<light source name>.visibilitymapcache.visibility.radius = 0.0
scene.lights.<light source name>.visibilitymapcache.visibility.glossinessusagethreshold = 0.05
Just enabling the cache should be enough for most scenes:
If you are seeing some artifact, try to increase the map resolution and/or sample per pixel:
scene.lights.<light source name>.visibilitymapcache.map.width = 256
scene.lights.<light source name>.visibilitymapcache.map.height = 128
scene.lights.<light source name>.visibilitymapcache.map.samplecount = 8
If you want to reduce the memory usage, reduce instead the map resolution. If you want to reduce the pre-processing time, try to reduce the samples per pixel and/or the map resolution too.
This is a 50 samples per pixel rendering without the cache:
and this with cache enabled:
The difference in penumbra areas can be really huge.
Everything is still untested/unknown. The 2 scene renderings posted in this thread are literally the only scenes ever rendered up to now.
Posted: Mon May 27, 2019 12:00 pm
Wow the difference is really big, but I do see some artifacting around the area of direct sun exposure, looks a lot like DLCS artifacting actually.
Posted: Tue May 28, 2019 7:32 am
I also wonder, why is the sunlit area noisy? Shouldn't that part be like instant clean?
Posted: Tue May 28, 2019 8:08 am
lacilaci wrote: Tue May 28, 2019 7:32 am
wonder the same. it is strange that the are that is directly illuminated stay so noisy
