Page 4 of 8
Re: Tiled OIDN Denoising
Posted: Wed Mar 20, 2019 2:15 pm
by CodeHD
B.Y.O.B. wrote: Wed Mar 20, 2019 1:59 pm
Not related to your problem, but I would try to de-duplicate the code
here and
here.
Try to do all the stripe processing in one for loop, without the code outside the loop.
You can check if you are doing the first stripe by testing (i == 0).
Good suggestion, but I have actually already done that in the meanwhile
I have also found the error for the problem above. I had written the denoised part including the overlap region back into the pixel array in each iteration. As a result, the next iteration received the already denoised overlap region together with the noisy rest.
I introduced a new overlapBuffer, and now it seems to finally work
I currently still have a battery of unused variables that I created when I cleaned up the loop, I will push the new code after taking care of that.
Finally some (low-res) test images.
The attachment RGB_IMAGEPIPELINE_0.png is no longer available
Posted: Wed Mar 20, 2019 3:02 pm
Nice progress
Posted: Wed Mar 20, 2019 3:51 pm
Looking good
Posted: Wed Mar 20, 2019 4:01 pm
Really inspiring result
Posted: Wed Mar 20, 2019 9:43 pm
by CodeHD
All working now
https://github.com/CodeFHD/LuxCore/blob ... l_oidn.cpp
https://github.com/CodeFHD/LuxCore/blob ... tel_oidn.h
I included a function to choose between tiled or simple OIDN based on resolution.
As by my explation before, I went for hard-coded 8 stripes, 100 pixel overlap region (2x50), and using the stripe-OIDN starting at 3840x2160 = 8.2944 MPixel. (I don't know how to include this into the settings, so that it could be changed in the cfg file.)
I just tried the hotel scene again at 7680x4320. Each OIDN stripe needed ~6-7 GB of RAM. My system (with 32GB RAM) stayed just withing 16GB total RAM usage that way, with some other applications open.
Posted: Wed Mar 20, 2019 10:30 pm
CodeHD wrote: Wed Mar 20, 2019 9:43 pm
You can parse properties here:
https://github.com/LuxCoreRender/LuxCor ... e.cpp#L603
Looking at the other plugins in that big if/else should help you see how it works, if it's not clear I can go into further detail.
Basically you first add the parameters to the plugin's constructor, then parse them from the .cfg file in the method I linked and pass them to the plugin when calling its constructor.
Posted: Wed Mar 20, 2019 10:44 pm
by CodeHD
B.Y.O.B. wrote: Wed Mar 20, 2019 10:30 pm
Looks like a good start, thanks!
Anyways, I probably won't be able to continue until Sunday, so feel free to copy the current, hard-coded version into the daily builds for others to test. If you think it is worth it, anyways
Posted: Wed Apr 03, 2019 11:43 am
CodeHD wrote: Sun Mar 17, 2019 12:30 am
kintuX wrote: Sat Mar 16, 2019 1:11 pm
Love glitches, love the work you do... keep fighting
BTW
Up to how many splits this tiling can do?
ie. What happens if number of splits is equal or exceeds number of pixels? Crash, glitch, warning or no work done?
Man, am eager to test it
Who said I won't keep fighting?
Mmmm... is it possible to give it a punch
can I?
Posted: Wed Apr 03, 2019 6:57 pm
by CodeHD
kintuX wrote: Wed Apr 03, 2019 11:43 am
can I?
Depending on how hard you punch...
No seriously though, I just came here to write an update. I am still quite busy at the moment, and will be on travel most of the time until (and including) easter (and just returned from one)...
Depending on what you mean by giving it a punch: go ahead and test it, develop it further. As I said above, the code as linked should work, you need (only
) to compile luxcore yourself with the two files changed. If you want to pounch me into continuing, I would only start again after easter, sorry...
Posted: Wed Apr 10, 2019 11:23 am
CodeHD wrote: Wed Apr 03, 2019 6:57 pm
can I?
OK. No problem, gave it a first punch - compiled it
Windows x64 LuxCore tiledOIDN binaries here).
First, "blind" test done
(I think - everyone is welcome to confirm, if it's working or not)
But I need to get and devote more-more time, diving deeper to get to grips with standalone, OCL, Blender, python and all... 2nd step is how to make an openCL build with it? slowly on to reading, getting characteristics, properties and associate it with Blender... ahhh... well - i'm just so slow
Anyways, Thank you for everything.
