Page 4 of 7
Re: first steps on luxcore
Posted: Tue Feb 13, 2018 2:35 pm
Yes, there seems to be a little discrepancy.
Can you make a bug report on github so I don't forget?
Just include the images and the test scene.
Posted: Tue Feb 13, 2018 2:58 pm
Sharlybg wrote: Tue Feb 13, 2018 1:45 pm 10sc each render on the same cpu/ no clamp for both/ shutter at 45 for both:
The Cycles motion blur looks very wrong, are you sure it isn't using a some fake approximation ?
Posted: Tue Feb 13, 2018 3:10 pm
B.Y.O.B. wrote: Tue Feb 13, 2018 2:35 pm Yes, there seems to be a little discrepancy.
Done thanks you ;)
here is the cycles Motion blur panel. but don't really know how they have implemented this inside the core.
but they recently get a huge boost in DOF AND MB: here you have more info about :
https://cloud.blender.org/blog/cycles-t ... 10x-faster
Posted: Tue Feb 13, 2018 4:34 pm
Sharlybg wrote: Tue Feb 13, 2018 3:10 pm here is the cycles Motion blur panel. but don't really know how they have implemented this inside the core.
Like I said the Cycles motion blur look wrong, there is barely any highlight motion blur. Are you using a not linear shutter curve ?
Posted: Tue Feb 13, 2018 4:50 pm
no shutter curve like in the panel i've uploaded
Posted: Wed Feb 14, 2018 10:21 pm
I've maybe found a bug here : my lake shader don't want to render in viewport (giving a matrix invert error output) and appear matte at final render. Blend attached :
https://drive.google.com/open?id=1CFVz- ... rt7gN2yN25
Posted: Wed Feb 14, 2018 10:57 pm
The Z scale of object "Plane.027" is set to 0.
If you change it to 1, it exports correctly.
Not sure how we should handle cases like this.
  • We could add a small epsilon to all values of the transformation matrix if determinant == 0 (when the matrix is non-invertible)
  • Or we could provide a better warning/error message
Posted: Wed Feb 14, 2018 11:26 pm
The first option is more user friendly !
Posted: Wed Feb 14, 2018 11:30 pm
Well, I kind of implemented both now.
You get a warning, but the object is exported regardless.
Posted: Thu Feb 15, 2018 8:22 pm
Luxcore Vs Cycles:
Both render under 1mn. same lighting condition. you will also notice that luxcore become darker and noisy when smoke volume is rendered while the lighting stay unchanged.
smoke off :
Luxcore
Cycles
smoke on :
Luxcore
Luxcore BiDir
Cycles
