Page 4 of 6
Re: Two well known luxcore problems.
Posted: Mon Aug 30, 2021 11:22 pm
daros wrote: Mon Aug 30, 2021 9:53 pm
Do you think you can do anything to reduce this halo on bidir?
It is a BiDir-only only problem and it is likely to be related to some wrong PDF (i.e. the weight of the mix between light tracing and path tracing). I'm looking into it (but it is quite complicated stuff).
Posted: Tue Aug 31, 2021 7:53 am
The fact that you know the source of the issue is a great progress by itself.
Posted: Wed Sep 01, 2021 9:15 am
I should have fixed the problem, this is a rendering with old code:
and with the new code:
Note how the fix doesn't affect only the edge but the overall look of the material.
Posted: Wed Sep 01, 2021 9:43 am
Congrats Dade !
Btw can we just download the last build and test it ?
Posted: Wed Sep 01, 2021 11:38 am
by chuchur
Hi Dade! Thank you for fixing it!
Was it the main reason?
if (directPdfW || reversePdfW) {
const float pdf = DisneyPdf(roughness, metallic, clearcoat, clearcoatGloss,
anisotropicGloss, localLightDir, localEyeDir);
if (pdf < 0.0001f)
return Spectrum();
if (directPdfW)
*directPdfW = pdf;
if (reversePdfW)
*reversePdfW = pdf;
I will try to merge it with my changes
Posted: Wed Sep 01, 2021 11:41 am
by daros
I don't know if this helps.
Those are real world samples of exactly the same set-up
Lime only, spehere and box.
Lime only+transparent lacquer, spehere only
enameled cermic, spehere only
Tone mapping of the photos is linear, no highlight compression, almost pure RAW, only white blance, camera Sony Alpha 7 III with 50mm Zeiss lenses.
Posted: Wed Sep 01, 2021 12:31 pm
daros wrote: Wed Sep 01, 2021 11:41 am
Could you share the lighting setup (diagram & full specs, if possible)? Unless you already recreated it digitally (1:1), then scene file would be most welcome...
appreciated!
PS
Also, did you took those with macbeth colorchart for color correctness? I wonder cuz of warm tone...
Posted: Wed Sep 01, 2021 12:45 pm
by daros
It's the same scene which has been shared by Sharlybg on page 3.
Fstop 22, shutter 1/10, iso 100, focus at the front of the sphere, camera position in the center of the hole of the backwall
White balance is the same for all materials we sampled, so some show up warmer and others colder.
Posted: Wed Sep 01, 2021 2:11 pm
chuchur wrote: Wed Sep 01, 2021 11:38 am
There were a couple of problems but the main reason was this:
https://github.com/LuxCoreRender/LuxCor ... y.cpp#L115
It is an old JeanPhi's idea: it is correct but it always slip under the radar of anyone not used to Lux code (i.e. the original Disney material code was written by a guy for his thesis a while ago and submitted as patch).
Posted: Wed Sep 01, 2021 3:09 pm
by chuchur
Hi Dade,
I've tried to merge, but now I've got a strange linker problem by building luxcoreconsole:
I can build slg-core.lib without a problem.
Sorry, just running cmake has helped
slg-core.lib(scene.obj) : error LNK2019: unresolved external symbol "public: static class slg::ImageMapResizePolicy * __cdecl slg::ImageMapResizePolicy::FromProperties(class luxrays::Properties const &)" (?FromProperties@ImageMapResizePolicy@slg@@SAPEAV12@AEBVProperties@luxrays@@@Z) referenced in function "private: void __cdecl slg::Scene::Init(class luxrays::Properties const *)" (?Init@Scene@slg@@AEAAXPEBVProperties@luxrays@@@Z)
2>slg-core.lib(imagemapcache.obj) : error LNK2001: unresolved external symbol "public: virtual class slg::ImageMap * __cdecl slg::ImageMapResizeNonePolicy::ApplyResizePolicy(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class slg::ImageMapConfig const &,bool &)const " (?ApplyResizePolicy@ImageMapResizeNonePolicy@slg@@UEBAPEAVImageMap@2@AEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AEBVImageMapConfig@2@AEA_N@Z)
2>slg-core.lib(imagemapcacheserialize.obj) : error LNK2001: unresolved external symbol "public: virtual class slg::ImageMap * __cdecl slg::ImageMapResizeNonePolicy::ApplyResizePolicy(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class slg::ImageMapConfig const &,bool &)const " (?ApplyResizePolicy@ImageMapResizeNonePolicy@slg@@UEBAPEAVImageMap@2@AEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AEBVImageMapConfig@2@AEA_N@Z)
2>slg-core.lib(parseshapes.obj) : error LNK2019: unresolved external symbol "public: __cdecl slg::CameraProjUVShape::CameraProjUVShape(class luxrays::ExtTriangleMesh *,unsigned int)" (??0CameraProjUVShape@slg@@QEAA@PEAVExtTriangleMesh@luxrays@@I@Z) referenced in function "private: class luxrays::ExtTriangleMesh * __cdecl slg::Scene::CreateShape(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class luxrays::Properties const &)" (?CreateShape@Scene@slg@@AEAAPEAVExtTriangleMesh@luxrays@@AEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AEBVProperties@4@@Z)
2>slg-core.lib(imagemapcacheserialize.obj) : error LNK2001: unresolved external symbol "public: virtual class slg::ImageMap * __cdecl slg::ImageMapResizeFixedPolicy::ApplyResizePolicy(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> > const &,class slg::ImageMapConfig const &,bool &)const " (?ApplyResizePolicy@ImageMapResizeFixedPolicy@slg@@UEBAPEAVImageMap@2@AEBV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@AEBVImageMapConfig@2@AEA_N@Z)
