Page 4 of 7
Re: Unified executable (for CPU-only, OpenCL and CUDA)
Posted: Fri May 29, 2020 10:55 am
Dade wrote: Thu May 28, 2020 9:43 pm
acasta69 wrote: Thu May 28, 2020 7:27 pm
Defining LUXRAYS_DISABLE_CUDA and LUXRAYS_DISABLE_OPENCL seems to have no effect: LuxCoreUI still allows to choose OCL render engines. I'll try to check why this happens.
Yes but it should have no device available at all for the rendering. I guess it could be removed from the menu too.
I updated LuxCoreUI to show OpenCL/CUDA related options only if OpenCL/CUDA is available at runtime.
Posted: Fri May 29, 2020 11:17 am
by u3dreal
In process of updating deps and azure files .... seems luxcore only needs libcuda.dylib and libnvrtc.dylib ...
Posted: Fri May 29, 2020 12:35 pm
by u3dreal
Done
No access to secure file for me .. should i merge ? otherwise no check possible. maybe you can check ..
https://github.com/LuxCoreRender/LuxCore/pull/381
Posted: Fri May 29, 2020 12:36 pm
u3dreal wrote: Fri May 29, 2020 11:17 am
Don't you need only libnvrtc.dylib ? Isn't libcuda.dylib already installed on the system by the driver ?
P.S. don't forget also the nvrtc-builtin DLL too.
Posted: Fri May 29, 2020 12:47 pm
by u3dreal
Dade wrote: Fri May 29, 2020 12:36 pm
Will have to check ..
OK which one is needed ?? libnvrtc-buildins.dylib or libnvrtc-buildins.10.1.dylib
Are you sure ??? if so i will have to add the path for libnvrtc-buildins also somewhere in the code ..
I checked with otool ... libtool for osx ... libcuda or libnvrtc do not depend on libnvrtc-buildins .. ?
I think libcuda is not included with the driver since it is in Developer folder ... which does not get created when installing just the driver
when could i notice that buildins is missing ?
Posted: Fri May 29, 2020 1:56 pm
It is explained here:
viewtopic.php?f=5&t=2201&start=20#p23231
You need to see both:
CUDA support: enabled
CUDA support: available
Posted: Fri May 29, 2020 2:23 pm
by u3dreal
Dade wrote: Fri May 29, 2020 1:56 pm
Ok then everything is fine now. I will commit.
Posted: Fri May 29, 2020 3:00 pm
by u3dreal
Wow new azure record 36min
So cool we just have to compile once .. all seems fine will test when linux and windows finished.
We should also update this
[ 88%] [BISON][lux_parser] Building parser with bison 3.6.2
/Users/runner/runners/2.168.2/work/1/s/src/luxcore/luxparser/luxparse.y:20.1-35: warning: deprecated directive: ‘%name-prefix "luxcore_parserlxs_yy"’, use ‘%define api.prefix {luxcore_parserlxs_yy}’ [-Wdeprecated]
20 | %name-prefix "luxcore_parserlxs_yy"
i use bison 3.6 now .. so it should be no problem on my side
Posted: Fri May 29, 2020 4:05 pm
by acasta69
Dade wrote: Fri May 29, 2020 10:55 am
The GPU devices are actually available, I think the two definitions are not passed on from cmake to the build stage:
CMake Warning:
Manually-specified variables were not used by the project:
Not a big problem in any case, I think.
Posted: Fri May 29, 2020 4:10 pm
by acasta69
I have updated the azure pipeline files for Windows and it's running now. I'll check the binaries as soon as they are available.
About Linux: is it enough to build only the version with neither "opencl" nor "cuda" in the directory name?
Or do you need to modify the build scripts in the "LinuxCompile" repo?
