After v2.0 is out, we will release v2.1alpha0 for testing.
Denoiser Integration
Re: Denoiser Integration
it is a stupid problem with newer GCC in Ubuntu 16.04 (I'm using Ubuntu 14.04LTS). It is trivial to fix once I get the errors, I will spin up a VM to compile on Ubuntu 16.04 to fix the problem.zezic wrote: Sat May 05, 2018 1:46 amCan we have binary build of this? I can't build it for some reason (Ubuntu 16.04): https://pastebin.com/sZtd89V7Dade wrote: Fri May 04, 2018 8:26 pm Added the support for denoising to TILEPATHOCL too, now all path tracers can use the denoiser.
Here's the progress of the denoiser integration in the Blender addon: https://github.com/LuxCoreRender/BlendL ... issues/153
If you have more ideas, tell me.
We need to do an a little animation out of this scene, something simple with camera moving around, just for testing. I will take care of doing the rendering.B.Y.O.B. wrote: Tue May 08, 2018 7:59 am A video demo of the current state of the denoiser in BlendLuxCore: https://youtu.be/1SJ4w4GFjAE
Yes ! moving camera and animated DOF will be greatWe need to do an a little animation out of this scene, something simple with camera moving around, just for testing. I will take care of doing the rendering.
This is the first working version of the BCD denoiser with BiDir:
It is a quite stretched application of BCD because of the way BiDir works. You may need more samples/pixel (compared to path tracing) and to tune a bit the denoiser parameters to obtain better result. However it still quite good.
I was taking a look, (whilst work at work today
), at the YouTube video you did earlier.
Looks great!
Looks great!
Hi Dade,
Is BCD main denoising code implemented in opencl or only CPU
If only CPU is it Multithreaded
20secs for denoising(if opencl) is a bit longer I think. May be I am expecting too much from BCDDade wrote: Wed May 02, 2018 10:33 am First rendering with OpenCL and denoiser:
With GPUs, it is a 20secs rendering and 20secs denoising![]()
Result is really good!!Dade wrote: Tue May 08, 2018 4:28 pm This is the first working version of the BCD denoiser with BiDir:
Well, 20secs for an image... when the alternative (no denoiser) is to wait minutes or hours to have the same "noisefree" level... is this real a problem?
