Page 4 of 6
Re: What is new in LuxCore API v2.0?
Posted: Tue Mar 27, 2018 9:54 am
neo2068 wrote: Tue Mar 27, 2018 7:16 am
Dade wrote: Mon Mar 26, 2018 10:04 pm
It is a lot faster and it works
I must admit I have still aliasing problem with sharp edges but there aren't usually a lot of sharp edges in most common heterogeneous volumes (i.e. smoke, etc.).
Just compile the latest sources and try to use an heterogeneous volume with density grid (btw, I added the OpenCL support for density grid texture too).
OpenCL support is really great. Thanks for that. I tried to implement that some time ago but only got frustrated as debugging the code was a nightmare.
It always is
Anyway the winning trick was to store the density grid 3D data as a 2D image map (x projected on image x and y/z on image y). I had already in place the infrastructure to encode/transfer image maps on GPUs and everything worked flawless once I used this trick (I hadn't to write any additional code).
Is there an automatic step size estimation for heterogeneous volumes?
No but the step size is now fixed (it was variable before) so if you want to render a 1 meter cube you know you are going to need a 5cm-20cm step size. It is not hard to setup once you know the step size in expressed in a real world unit.
Aliasing was bad with the old code, too, and multiple scattering volumes wasn't as bright as rendered with other renderers. I have to try it.
Single scatter:
Multi-scattering
It is also so much faster, multi-scattering at 9M samples/secs:
Posted: Tue Mar 27, 2018 1:45 pm
by Odilkhan Yakubov
Is it possible to add some HD Cache or add the secondary engine like Corona renderer?
Posted: Tue Mar 27, 2018 1:52 pm
Odilkhan Yakubov wrote: Tue Mar 27, 2018 1:45 pm
What does Corana do ? Do they compose rendering by doing volume rendering in a separate step with a separate engine
For HD cache, do you mean the Corona light cache ?
Posted: Tue Mar 27, 2018 2:08 pm
Some engines use different integrators for primary/secondary bounces.
E.g. V-Ray:
https://docs.chaosgroup.com/display/VRA ... Parameters
edit: their nomenclature is a bit weird, I think with "primary bounces" they mean the first indirect bounce, and with "secondary bounces" all following bounces.
Maybe this image shows it:
https://docs.chaosgroup.com/display/VR2R/Brute+Force+GI
Posted: Tue Mar 27, 2018 2:19 pm
by Odilkhan Yakubov
Dade wrote: Tue Mar 27, 2018 1:52 pm
Seems like that, but just a little bit different
Posted: Tue Mar 27, 2018 2:20 pm
by Odilkhan Yakubov
Is there planned bucket rendering not Progressive refine (like now, like Cycles)?
Posted: Tue Mar 27, 2018 2:24 pm
Odilkhan Yakubov wrote: Tue Mar 27, 2018 2:20 pm
This is already available as Tile rendering. See option in render engine setting.
Posted: Tue Mar 27, 2018 2:25 pm
It is already available (TILEPATH engine).
In BlendLuxCore, it is available in the render settings: Just enable the "Tiled" checkbox.
Posted: Tue Mar 27, 2018 2:27 pm
by Odilkhan Yakubov
Oh, its my mistake.
Posted: Tue Mar 27, 2018 8:53 pm
by neo2068
I like the new volume rendering.
It is very fast and looks awesome.
PathOCL, multiple scattering
