Page 4 of 7
Re: Compile on MacOS 10.13
Posted: Sat Dec 07, 2019 2:04 pm
by u3dreal
Yeah that makes sense. The alpha is pretty stable anyway.
I wonder if it would be possible just to use libs installed with brew now that we figured out that static linking :)
or does Lux need exact lib versions to work ?
Oh and on the LuCore 2.1 test scene i get an error of jpg beeing too new. version 90 expected 80 . Could this be an old
jpg version in the macoscompile git ? v9b i guess ... that should not be too old ... well 2 years .. should i update to v9c ?
Does anyone know how to fix the permissions issue with the denoise executable ?
Posted: Sat Dec 07, 2019 3:51 pm
u3dreal wrote: Sat Dec 07, 2019 2:04 pm I wonder if it would be possible just to use libs installed with brew now that we figured out that static linking :)
Most of the times, yes, you need the exact version otherwise you can experience a lot of subtle and unknown problems compared to the other 2 platforms (Linux+Windows).
u3dreal wrote: Sat Dec 07, 2019 2:04 pm Does anyone know how to fix the permissions issue with the denoise executable ?
If you use tar instead of zip, it will save file "read/write/execute bits.
Posted: Sat Dec 07, 2019 4:43 pm
by u3dreal
good to know i'll try
So all the dependnecies in MacOsCompile repo are up-to-date now ??
And yes should i commit the changes made ? Review someone :)
Posted: Sat Dec 07, 2019 6:17 pm
u3dreal wrote: Sat Dec 07, 2019 4:43 pm So all the dependnecies in MacOsCompile repo are up-to-date now ??
I have no idea :mrgreen:
u3dreal wrote: Sat Dec 07, 2019 4:43 pm And yes should i commit the changes made ? Review someone :)
You can use GitHub pull request process to submit any change to the repository :idea:
Posted: Sat Dec 07, 2019 6:55 pm
by u3dreal
Sorry i don't get it. I have cloned the lux repo and now i would like to push not pull .. :D maybe got that wrong
guess not anyone can push to the repo :)
Never done that. I would like to commit these changes.
or will i have to make a new branch ??
Posted: Sat Dec 07, 2019 9:40 pm
It is explained here: https://help.github.com/en/github/colla ... l-requests
You clone the repository on GitHub so you have your own copy, you create a branch with all your patches and submit a "pull request".
It is a method so anyone can submit patches to an "official" repository.
Posted: Sat Dec 07, 2019 9:50 pm
by u3dreal
OK lets see --... i'll check the build_deps script once more and then i'll push Macosdeps repo first
Posted: Sun Dec 08, 2019 12:49 am
by u3dreal
OK now there should be a pull request for MacOSCompileDeps
Posted: Sun Dec 08, 2019 3:48 pm
by u3dreal
I'm still investigating the jpg error.
Error opening image file : /var/folders/zh/g9zxh0gs09v2j_tfw8by4v0r0000gn/T/tmp78a0ujo3.jpg (error = JPEG error: Wrong JPEG library version: library is 90, caller expects 80 ("/var/folders/zh/g9zxh0gs09v2j_tfw8by4v0r0000gn/T/tmp78a0ujo3.jpg"))
could it be the lib is tooo new ??? v9b was is the mac repo v3c bringst the same error and in the linux repo i can find version v6?
Strange....
Posted: Sun Dec 08, 2019 5:13 pm
Are you having this problem inside Blender and/or with LuxCoreUI ?
