Page 4 of 5
Re: Light tracing and pool
Posted: Mon Sep 02, 2019 7:16 pm
by FarbigeWelt
Fox wrote: Mon Sep 02, 2019 6:55 pm
FarbigeWelt wrote: Mon Sep 02, 2019 6:01 pm
How much time did this render take on what cpu?
It must have been 8-10 hours overnight on e5 2620 v4 cpu.
I play with the scene more, see if something better comes out of it.
Fox, thank you for answering!
www.cpubenchmark.net
02. Sep 19 Intel Xeon E5-2620 v4 @ 2.10GHz
| Intel Core i7-4770K @ 3.50GHz
| | AMD Ryzen 9 3900X
Single Thread Rating 1547 2250 2918
CPU Mark 11354 10074 31827
Price $363.45 $330.7 $669.99
Socket Type FCLGA2011-3 LGA1150 AM4
CPU Class Server Desktop Desktop
Clockspeed 2.1 GHz 3.5 GHz 3.8 GHz
Turbo Speed Up to 3.0 GHz Up to 3.9 GHz Up to 4.6 GHz
# of Physical Cores 8 (*2) 4 (*2) 12 (*2)
Max TDP 85W 84W 105W
Yearly Running Cost $15.51 $15.33 $19.16
First Seen on Chart Q2 2016 Q2 2013 Q2 2019
# of Samples 101 9005 540
Intel-Xeon-E5-2620-v4-vs-Intel-i7-4770K-vs-AMD-Ryzen-9-3900X
Posted: Tue Sep 10, 2019 12:40 pm
by Fox
This photon blotches are hard to get ride of
Posted: Tue Sep 10, 2019 2:09 pm
by epilectrolytics
Fox wrote: Tue Sep 10, 2019 12:40 pm
Now that's a maxed out setting table
But the result looks good though PathCPU & Metro together with caustic cache should render double caustics (+SDS).
I have been thinking a hybrid engine with PathCPU Metro for caustics+SDS only and PathOCL for the rest would be interesting
Posted: Tue Sep 17, 2019 12:46 am
by Fox
Getting closer, but there are this huge spots.
4h cpu hybridbackforward photongi
screen.tool.type = IMAGE_VIEW
periodicsave.film.outputs.period = 7200
film.outputs.safesave = 1
path.pathdepth.total = 33
path.pathdepth.diffuse = 33
path.pathdepth.glossy = 33
path.pathdepth.specular = 32
path.hybridbackforward.enable = 1
path.hybridbackforward.partition = 0.5
path.hybridbackforward.glossinessthreshold = 0.0040000001899898052
sampler.sobol.adaptive.strength = 0
sampler.random.adaptive.strength = 0
sampler.metropolis.largesteprate = 0.10000000000000001
sampler.metropolis.maxconsecutivereject = 32768
sampler.metropolis.imagemutationrate = 0.10000000000000001
film.filter.width = 1.5
film.height = 3000
lightstrategy.type = "POWER"
film.width = 4000
film.filter.type = "NONE"
sampler.type = "METROPOLIS"
renderengine.type = "PATHCPU"
scene.epsilon.max = 0.35699999332427979
scene.epsilon.min = 0.00013830000534653664
film.opencl.enable = 0
path.photongi.caustic.lookup.normalangle = 9.9999997090929202
path.photongi.caustic.enabled = 1
path.photongi.caustic.updatespp = 25
path.photongi.caustic.lookup.maxcount = 1024
path.photongi.persistent.file = ""
path.photongi.indirect.haltthreshold = 1
path.photongi.indirect.usagethresholdscale = 2
path.photongi.caustic.merge.radiusscale = 0
path.photongi.indirect.lookup.normalangle = 9.9999997090929202
path.photongi.photon.maxdepth = 32
path.photongi.indirect.glossinessusagethreshold = 0.0040000001899898052
path.photongi.caustic.maxsize = 100000000
path.photongi.photon.maxcount = 100000000
path.photongi.caustic.lookup.radius = 0.001
path.photongi.indirect.maxsize = 0
path.photongi.indirect.lookup.radius = 0.019880000501871109
path.photongi.indirect.enabled = 1
path.forceblackbackground.enable = 0
filesaver.format = "TXT"
filesaver.renderengine.type = "PATHCPU"
native.threads.count = 14
renderengine.seed = 1
batch.haltspp = 0
batch.halttime = 0
film.imagepipelines.0.0.type = "NOP"
film.imagepipelines.0.1.type = "TONEMAP_REINHARD02"
film.imagepipelines.0.1.prescale = 0.80000001192092896
film.imagepipelines.0.1.postscale = 6
film.imagepipelines.0.1.burn = 10
film.imagepipelines.0.2.type = "CAMERA_RESPONSE_FUNC"
film.imagepipelines.0.2.name = "FUJICOLOR-PRO-400H.crf"
film.imagepipelines.0.3.type = "GAMMA_CORRECTION"
film.imagepipelines.0.3.value = 2.2000000000000002
film.imagepipelines.0.radiancescales.0.enabled = 1
film.imagepipelines.0.radiancescales.0.globalscale = 0.4
film.imagepipelines.0.radiancescales.0.temperature = 5400
film.outputs.0.index = 0
film.outputs.0.filename = "RGB_IMAGEPIPELINE_0.png"
scene.file = "scene.scn"
Posted: Tue Sep 17, 2019 6:21 am
by epilectrolytics
This looks great!
And I like the spots too (Laci was asking for lens flares anyways...)
Posted: Wed Sep 18, 2019 5:50 am
Just by the way... here's how it looks faked in cycles
rendered in ~3 minutes...
It has few issues that could be solved, but often this would be good enough and fast enough... The flexibility rayswitching allows for is just amazing(not just for faking caustics..)
Posted: Thu Sep 19, 2019 4:17 pm
lacilaci wrote: Wed Sep 18, 2019 5:50 am
They are not exactly hard to fake in LuxCore too:
with the not so small difference that they are true caustics instead of faked one.
Posted: Thu Sep 19, 2019 4:43 pm
Dade wrote: Thu Sep 19, 2019 4:17 pm
except you get no refractions and you get really weird darkening on meshes under water...
Posted: Fri Sep 20, 2019 12:02 pm
by Fox
This is not a 3 minutes, but i found most interesting how much the HDR improves water.
Posted: Sat Sep 21, 2019 7:11 am
by kintuX
CPU PT
Halt Time: 90 s
Same geo, same IORs, colours HEX, default Sun & Sky...
LuxCore (w/ light tracing and all caches ON)
Corona ("Fast caustics solver" & "Generate caustics from environment")
About "Too Dark & Too Bright"... From real world I'd say LuxCores reflected caustics are more correct, it's only too much loos in refractive volume under glass (
my old enemy). I suspect there's a mistake somewhere about how gamma is handled. Look at the corners how light bounced in Lux version gets darker
Of course I can be wrong.
Also, Corona is much simpler, faster to set & reach the goal... while user also gets a caustic pass to fiddle with in post (if needed).
