Page 4 of 5
Re: Swimming pool / Underwater / Caustics
Posted: Tue May 07, 2019 3:04 pm
by epilectrolytics
fabi wrote: Mon May 06, 2019 9:23 pm
So when indirect and caustics caches are enabled, I understand that the caustics cache is computed with a number of visible objects which is inferior as it should be
Thanks for reporting this, maybe Dade can look into this and maybe fix it?
Caustic cache shouldn't get decreased when combined with indirect one.
Posted: Fri May 10, 2019 6:48 pm
I replaced the tile texture so we can make this into an example scene.
Also added dispersion as a test, I like it (maybe make it a bit more subtle).
Not finished yet, have to tune the materials and lighting a bit (env. light is a bit too dark).
Just a denoised low sample render because my notebook has a weak CPU, tomorrow I get access to my main PC again.
Posted: Sat May 11, 2019 3:18 pm
by Fox
That scene looks very cool. Too bad the volumetric light is way too slow to render.
Selfie / Underwater / Caustics
Posted: Sun May 12, 2019 1:21 pm
by epilectrolytics
Good idea to add the sculpture!
"...and the selfie-cam of the new iphone
is now water-proof up to six feet under!"
Posted: Sun May 12, 2019 11:13 pm
by Fox
@ epilectrolytics
This must have been some serious render time
Posted: Mon May 13, 2019 6:57 am
by epilectrolytics
Fox wrote: Sun May 12, 2019 11:13 pm
BiDir 1200 samples + OIDN = 3h on Ryzen 2700X
Also there is a procedural bump texture not helping with the speed, so yeah, not animation ready...
Posted: Mon May 13, 2019 10:44 am
by Fox
3h is awesome result, i thought it to be way way more.
Posted: Mon May 13, 2019 2:32 pm
@epilectrolytics nice result, would also make a good example scene on its own!
Here's a longer render (around 1h 20min) with larger resolution on a more powerful computer, 1300 samples + denoising.
I tuned down the dispersion a bit (from 0.003 to 0.0015).
Posted: Tue May 14, 2019 12:39 am
by Fox
@ B.Y.O.B.
I like it.
Posted: Tue May 14, 2019 7:59 am
by epilectrolytics
B.Y.O.B. wrote: Mon May 13, 2019 2:32 pm
Thanks, I'm still experimenting with materials and will report back when satisfied (will take some time because of a current animation render).
Good job with the pool scene!
