You can use the "uv" texture to get the UV coordinates of a mesh as a color in the material, might help with debugging:
https://wiki.luxcorerender.org/LuxCore_ ... 2#Type:_uv
Thank you, everybody.
Problem solved.
Problem solved.
Add support for OpenCL Devices, i found a small issue that we need to find out how many OpenCL devices are available. I'll fix it later.
Except that, everything works fine.
LuxCore API has a function to return a full description of all OpenCL devices available, is it what you need ?TAO wrote: Sun Apr 21, 2019 3:15 pm Add support for OpenCL Devices, i found a small issue that we need to find out how many OpenCL devices are available.
I would be interested.. isn't it all in the benchmark?
Thank you, Dade.Dade wrote: Sun Apr 21, 2019 3:27 pmLuxCore API has a function to return a full description of all OpenCL devices available, is it what you need ?TAO wrote: Sun Apr 21, 2019 3:15 pm Add support for OpenCL Devices, i found a small issue that we need to find out how many OpenCL devices are available.
I will try that and let you know. but i think, i need to do that inside 3dsmax before call LuxCore, 3dsmax has a bunch of internal function for this kind of things.
Thank you to mention that, I'm going to take a look at benchmark code too.
But i think it's going to be a bit different because it will be better to read this type of information before calling the renderer and as i mentioned before 3dsmax already has a few functions that can return the information we need here. So it's better to do as much as possible inside 3dsmax instead calling LuxCore over and over.
That's just my opinion for this and i will consider other solutions too.
You don't need a rendersession or anything to call this function.
In BlendLuxCore I do it here: https://github.com/LuxCoreRender/BlendL ... ncl.py#L64
The corresponding C++ function is GetOpenCLDeviceDescs(): https://github.com/LuxCoreRender/LuxCor ... e.cpp#L198
Perfect, Thank you.
First Lux Light is born inside 3dsmax. Lux Point Light
New shape for Lux Camera, Not that different
