Page 28 of 92
Re: BlendLuxCore Development
Posted: Fri Mar 23, 2018 6:21 pm
by Asticles
Why not convert the blackbody color to rgb?
Posted: Fri Mar 23, 2018 6:48 pm
That's the plan.
Posted: Thu Mar 29, 2018 6:24 pm
It's make a tie since i want talk about it. but don't know :
--- Can we add an option to control translucency level in glossy/matte translucent shader ?
--- Also there is know to control light importance in node iditor (maybe because of the upcomming light cache ?)
Posted: Thu Mar 29, 2018 6:38 pm
Sharlybg wrote: Thu Mar 29, 2018 6:24 pm
It is controlled by the diffuse and transmission colors.
But if you use a bright diffuse color, only the non-reflected light can get transmitted (because of energy conservation).
So if you have for example diffuse color 0.7 and transmission color 0.8, the transmitted light will be:
non_reflected = 1.0 - 0.7 = 0.3
transmitted = min(non_reflected, 0.8) = min(0.3, 0.8) = 0.3
So you get 0.3 transmitted light, even though you set 0.8, because most light is reflected.
Hope this clears it up, or is it even more confusing?
Maybe I can show the result of this calculation in the material nodes (only possible if not using textures).
Or did I misunderstand you and you meant something else?
I think I added it a few days ago, it was simply not implemented yet, has nothing to do with light cache.
Posted: Thu Mar 29, 2018 6:47 pm
It's clear ! Thanks You
Posted: Fri Mar 30, 2018 5:03 pm
[Tonemapper] Is Analog Film Simulation still coming in or is it no more? If yes, could LUTs be also supported?
Posted: Fri Mar 30, 2018 5:59 pm
Blender has this feature in the color management settings.
It is superior to a BlendLuxCore implementation because it can even be adjusted after a render is finished.
So I saw no point to implement the LuxCore imagepipeline plugin, I think the presets are mostly the same anyway.
A more interesting feature would be indeed an imagepipeline plugin which supports custom LUTs, but I think it is rather low priority compared to other stuff we have on our todo list.
Posted: Fri Mar 30, 2018 6:40 pm
Yes, am aware of Blender's color management. There's just no easy way to use custom .crf. If it's not too much, could at least reading from file be supported as it used to be?
Posted: Fri Mar 30, 2018 7:20 pm
B.Y.O.B. wrote: Fri Mar 30, 2018 5:59 pm
But isn't it exactly what camera response plugin (with a custom file) already does
P.S. for custom file I mean .crf file.
Posted: Fri Mar 30, 2018 8:09 pm
Sorry, I completely forgot you can already use a custom file.
I will add the plugin.
