I added the support for "batch.haltthreshold.stoprendering.enable", default value true. It can be set to false for not halting the rendering.B.Y.O.B. wrote: Sat Feb 24, 2018 8:09 amCan you add an option to control this "halt threshold without actual halting"?Dade wrote: Sat Feb 17, 2018 5:28 pm You are not setting the halt threshold parameter so the default value (0.02) is used.
Or can I already achieve this with the current properties?
Convergence based adaptive sampling
Re: Convergence based adaptive sampling
jensverwiebe
- Supporting Users
@Dade
You erratically wrote "Fitler" ( instead of Filter ) across the commit, just fyi so you won't run into
issue next round of commits.
