Re: DLSC Explained
Posted: Mon Dec 03, 2018 7:33 pm
found the problem :
Nvidia Titan black render :
AMD R9 390 render :
AMD R9 390 render :
Uh, that looks like a driver bug, you could try to check if there is an updated version (but I'm not sure if the 390 driver is still updated/maintainedSharlybg wrote: Mon Dec 03, 2018 7:33 pm found the problem :
AMD R9 390 render :
Updated to the lastest driver don't fix it . anyway i move forwardUh, that looks like a driver bug, you could try to check if there is an updated version (but I'm not sure if the 390 driver is still updated/maintained).
Looks like I have the same amd driver issue with the bathroom scene. I can check this evenig with the scene here.Dade wrote: Mon Dec 03, 2018 8:16 pmUh, that looks like a driver bug, you could try to check if there is an updated version (but I'm not sure if the 390 driver is still updated/maintainedSharlybg wrote: Mon Dec 03, 2018 7:33 pm found the problem :
AMD R9 390 render :
