Page 3 of 22
Re: Mac OS
Posted: Sun Jan 28, 2018 9:57 pm
by jensverwiebe
Nono, in the top cmakelists.txt, line 30ff
under
# Fresh start
cmake_minimum_required(VERSION 3.0)
cmake_policy(VERSION 3.0)
Later Dade can ifdef such.
Re: Mac OS
Posted: Sun Jan 28, 2018 10:05 pm
by patrickwalker
Well, a.out is usually the filename of compile code out of a C compiler so was just wondering. Might just be an option for a CC command in the script.
I added the lines to CMakeLists.txt and cmake still generates the missing pthread.h error.
(Assuming that +eventually above that was sandwiched between cmake_policy() entries isn't to be added in).
Re: Mac OS
Posted: Sun Jan 28, 2018 10:09 pm
by jensverwiebe
patrickwalker wrote: Sun Jan 28, 2018 10:05 pm
Those a.out may be from the cmake compiler testrun.
TBH: this all can become a big hazzle on untested macOS version. I'am not even sure Apple
updated bison and yacc to working version in between.
You must go through this step by step.
..and sure, the proposed testing was:
# Fresh start
if(APPLE)
cmake_policy(SET CMP0043 OLD)
cmake_policy(SET CMP0003 NEW)
cmake_policy(SET CMP0005 NEW)
cmake_policy(SET CMP0010 NEW)
cmake_policy(SET CMP0014 NEW)
endif(APPLE)
Jens
Re: Mac OS
Posted: Sun Jan 28, 2018 10:21 pm
by patrickwalker
Okay, so could the pthread.h file path be hardcoded into the cmake configuration for macOS? Not sure if this is true for any other version of Xcode but most people will have the latest one, or if they don't, they'll end up having to get the latest one from the App Store anyways.
This is the file path for it:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/pthread.h
Well, bison can be installed via Homebrew, and the current version for High Sierra is 3.0.4.1. yacc is hard linked into /usr/bin and *could* be changed by disabling CSR. Can macOS users be told to install bison using brew then set LD flags to '/usr/local/opt/bison/lib'?
Re: Mac OS
Posted: Sun Jan 28, 2018 10:33 pm
by jensverwiebe
You can answer some questions yourself if you read the old "macos" repo documentation.
Finding threads is a module in cmake, you can lookup there if the pathes are correct.
Compile bison and yacc statically, really investigate the lux macos repo, you will see what i did there.
Disabling System Integrity Protection (SIP) is not needed, in case you need newer binaries, install to /usr/local.
This will override /usr.
Make yourself clear, its a huge task. When getting libs from homebrew or whatever thus not compile yourself,
make sure with otool that those are linked with the proper sdk ( 10.9 ideally ). I also mentioned Blender
darwin repo consists of almost all libs already in c++11 you need for luxcore.
Jens
Re: Mac OS
Posted: Sun Jan 28, 2018 11:41 pm
by patrickwalker
I did read it, I updated all dependencies that were listed in the document, the exception being embree but I remember something being said about that.
In my hopes to get this working, these are the versions currently installed:
bison (3.0.4_1)
boost (1.66.0)
freeimage (3.17.0_1)
glew (2.1.0)
OpenEXR (2.2.0)
OpenImageIO (1.7.17)
libpng (1.6.34)
libtiff (4.0.9_1)
libjpeg (9b)
When I attempt to use the cmake commands with any options, I get errors.
I just have to say that I'm at a point in my life where I have fewer days ahead of me than behind me, and I really don't want to be wasting them on the intricacies and vagaries of "software engineering." My job description doesn't really include time for that and I spent way too much of my youth wasted on computers and have no desire to repeat that. Like a car, I should be able to turn it on and use it, not rebuild it from scratch every so often.
Re: Mac OS
Posted: Mon Jan 29, 2018 2:54 am
by patrickwalker
I erased and redownloaded everything. Managed to get GUI version of cmake generate the Xcode file, however, I'm getting errors. The root cause might be that Xcode cannot find embree2/rtcore_builder.h as referenced in bvhembreebuild.cpp.
I had hoped it was included in TBB, but I cannot find it in the usual locations. The macos block of files does seem to have all the other rtcore_* files.
Another thread had someone else with a similar missing header file issue. So, I downloaded a tar.gz and copied those header files into the luxcore source tree and seems to have cleared that problem. Unsure whether this is a proper solution and wondering how I'll pay for it later in the compilation/linking process, but it moves right on into the next error. And this error I have no clue how to handle. The only thing I can say is that CG probably means CoreGraphics but it's been six or seven years since I even did any macOS programming at all and that was using Objective-C.
Now, in the method OpenCLDeviceDescription::GetOCLContext() found in device.cpp, it is saying that CGLGetCurrentContext is an undeclared identifier.
Re: Mac OS
Posted: Mon Jan 29, 2018 9:30 am
patrickwalker wrote: Mon Jan 29, 2018 2:54 am
The cmake/SpecializedConfig/Config_OSX.cmake file reference Embree path with the following lines:
SET(EMBREE_LIBRARY ${OSX_DEPENDENCY_ROOT}/lib/embree2/libembree.2.8.0.dylib)
You have probably only to fix the right path there and to use the latest Embree available from
https://embree.github.io/downloads.html (older versions do not include the embree2/rtcore_builder.h).
The OpenGL/OpenCL interoperability is not even used by LuxCoreRender so if you want try to move on instead than fixing that problem, you can just comment the code:
/*if (enableOpenGLInterop) {
#if defined (__APPLE__)
CGLContextObj kCGLContext = CGLGetCurrentContext();
CGLShareGroupObj kCGLShareGroup = CGLGetShareGroup(kCGLContext);
cl_context_properties cps[] = {
CL_CONTEXT_PROPERTY_USE_CGL_SHAREGROUP_APPLE, (cl_context_properties)kCGLShareGroup,
0
#else
#ifdef WIN32
CL_GL_CONTEXT_KHR, (intptr_t)wglGetCurrentContext(),
CL_WGL_HDC_KHR, (intptr_t)wglGetCurrentDC(),
CL_CONTEXT_PLATFORM, (cl_context_properties)platform(),
0
#else
CL_GL_CONTEXT_KHR, (intptr_t)glXGetCurrentContext(),
CL_GLX_DISPLAY_KHR, (intptr_t)glXGetCurrentDisplay(),
0
#endif
#endif
oclContext = new cl::Context(devices, cps);
} else {*/
CL_CONTEXT_PLATFORM, (cl_context_properties)platform(), 0
P.S. the solution to the last problem is probably about adding the right "#include" header where the CGL* functions are declared on your platform.
Re: Mac OS
Posted: Mon Jan 29, 2018 12:36 pm
by jensverwiebe
This looks as you are coming along in a way
Keep in mind macOS has changed in every iteration, so some functions could have been gone ( metal transition ).
Also always keep an eye Apple often does little special things with pathes.
I guess you setup a macos repo ? aka ${OSX_DEPENDENCY_ROOT} ? Hint: embree/tbb headers are in an embree2 subdir.
Embree libs come with symlinks so SET(EMBREE_LIBRARY ${OSX_DEPENDENCY_ROOT}/lib/embree2/libembree.2.dylib)
should do.
I can just emphasize my 2 1/2 years old osx 10.11 repo for lux c++11 is still doing fine, so it is mainly to find the
changes made in 10.13 sdk to make the last bits work.
Don't complain about lux devs for not having ootb compile, its Apple being a moving target.
I bet you will get it done asap
Keep on ...
Jens
Re: Mac OS
Posted: Mon Jan 29, 2018 1:45 pm
by patrickwalker
Dade wrote: Mon Jan 29, 2018 9:30 am
So, here's where some fun begins. I did a full HDD search and it is not finding this dylib. I've gone through the usual spots and cannot find them. That error seems to have disappeared as
0
#else
#ifdef WIN32
0
#else
0
#endif
#endif
} else {*/
As soon as I try to comment it out, I get more undeclared identifiers.
Not sure how to handle this now. I've looked up the reference at the Developer website hoping for some info about header file locations and not seeing anything. Throw in the fact the source code is in C++, which I have always avoided, doesn't help. I wouldn't be so lost if it was in Objective-C.
