Re: DLSC test
Posted: Sun Sep 30, 2018 7:14 pm
here the scene
https://we.tl/t-0gsJXscmDi
Don't use the synthetic Sky but HDRI/IBL.marcatore wrote: Sun Sep 30, 2018 12:27 pm I've problem with DLCS.
This is what I've
Lux2.1 alpha4 using GPU
All default settings
There are that blobs.
Any suggestions?
Well your own test there actually shows that it is not sky or hdri but a combination of sun and sky or hdri or flat color.kintuX wrote: Sun Sep 30, 2018 9:00 pmDon't use the synthetic Sky but HDRI/IBL.marcatore wrote: Sun Sep 30, 2018 12:27 pm I've problem with DLCS.
This is what I've
Any suggestions?
Check more about it here: viewtopic.php?f=9&t=472&start=10#p4808
Welllacilaci wrote: Mon Oct 01, 2018 6:15 am Well your own test there actually shows that it is not sky or hdri but a combination of sun and sky or hdri or flat color.
For example I rarely use HDRI cause they only make sense in some cases. For example in most archviz I do use sun and sky system, so what do I do if I want to use sun&sky and many interior lights that could benefit from DLCS?
It should still not cause artifacts. Seems like a bug to me.Sharlybg wrote: Mon Oct 01, 2018 9:53 am DLCS is not design for this kind of scene or i'm completly wrong![]()
Yes of courseIt should still not cause artifacts. Seems like a bug to me.
I think that is a sampling problem: DLSC trys to establish if the light is visible with very few rays (in order to speed up the pre-processing phase). But trying to establish if the Sky light source is visible with only ~16 rays can lead to false positive/negative in indoor scenes. I will check but I'm pretty sure this is the explanation.lacilaci wrote: Mon Oct 01, 2018 10:24 am maybe it's a problem of mostly uniform lighing that sky creates or completely uniform from flat color? Confusing lightcache?
