Page 3 of 7
Re: first steps on luxcore
Posted: Sun Feb 04, 2018 5:21 pm
Sharlybg wrote: Sun Feb 04, 2018 5:05 pm turn arround suzane and tell me if all is correct. look the eye from the side and back/top.
The suzanne model is non-manifold, which makes it unsuited for anything with transparent/translucent materials.
It is expected to look wrong with volumes, glass etc.
Sharlybg wrote: Sun Feb 04, 2018 4:51 pm This also wan't render :
Thanks for the simpler scene.
The error seems to happen when using a mix material and a volume on a material output.
Have to debug further.
Posted: Sun Feb 04, 2018 5:29 pm
Sharlybg wrote: Sat Feb 03, 2018 10:07 pm test name bug.blend
I fixed the bug.
Posted: Sun Feb 04, 2018 5:33 pm
I fixed the bug.
Bravo. ;)
Posted: Fri Feb 09, 2018 3:05 pm
I've the felling that volume is not working as expected :
https://drive.google.com/open?id=1n7vqD ... rrK6oLVcfY
Posted: Fri Feb 09, 2018 3:45 pm
Can you explain what you are trying to do?
It looks like you have 4 Volumes in the scene. The world, cube and camera are all using a different volume each.
Posted: Fri Feb 09, 2018 3:59 pm
something like this (simulating ambient fog around the sphere) :
http://forums.luxcorerender.org/downloa ... &mode=view
just make an error on the cube volume: it should be cubeV(volume). but the result is not right :?
Posted: Fri Feb 09, 2018 4:55 pm
I think you can just assign one volume to the world, that's enough.
The world volume should be a homogeneous volume with multiscattering disabled and scattering scale around 0.1 for fog.
You can delete the cube I think.
And camera can be switched to auto-detect volume.
Posted: Tue Feb 13, 2018 1:45 pm
Cycles motion blur vs Luxcore motion blur
10sc each render on the same cpu/ no clamp for both/ shutter at 45 for both:
luxcore
cycles
blend
mustang fire.blend
(4.64 MiB) Downloaded 459 times
Posted: Tue Feb 13, 2018 1:57 pm
You have to raise the amount of steps (camera settings, below shutter).
This kind of movement can not be interpolated correctly with only 2 steps.
This is with 20 steps (maybe you need less/more):
Posted: Tue Feb 13, 2018 2:12 pm
nice thanks for the tips. do you also think it is possible to mimic the same result ? also why our Motion blur is so noisy ?
luxcore
cycles
EDIT
I'm also experimenting a slow down in render due to noisy deph of field.
