Light emitting instances
Re: Light emitting instances
daros wrote: Fri Feb 19, 2021 11:29 am Yes, Cycles starts to render immediately with this scene.
Cycles access directly internal Blender structures and doesn't support scene editing: in LuxCore you can edit/delete one of the 18,000,000 light sources by name (so it needs to set up the required structures to access the named object).
I have optimized the mesh light parsing code.
Step #1
The first step was to discover how slow is boost::unordered_map structure (aka hash table). I replaced boost::unordered_map with robin_hood::unordered_flat_map (https://github.com/martinus/robin-hood-hashing).
This reduced the parsing time from 32secs to 19secs.
Step #2
I than discovered that computing hash of object names was taking a long time due to the extreme length of the names used by BlendLuxCore. It uses names like "139760923179016_1397609231759440_0_2147483647_2147483647_2147483647_2147483647_2147483647_2147483647_0_0_0_0_0_0_0_00dupli4460" ... is a bit long, isn't it ?
I worked around this problem computing the hash on a pre-encoded version of the name.
This reduced the parsing time from 19secs to 15secs.
Step #3
I than discovered that converting the triangle light index to string was taking a significative amount of time (because some generic code to handle locale problems when converting floating point numbers). I added an optimized and dedicated path fro this case.
This reduced the parsing time from 15secs to 10secs.
So now the scene parsing is more than 3 times faster. Note: this code is on "for_v2.6" branch.
Great job, 3 times faster that means a lot.
Is replacing boost::unordered_map with robin_hood::unordered_flat_map have any benefit in other cases, or do you have any suggestion for using it, if there is i be able to use it in the 3dsmax plugin, or is not necessarily.
Great! Very nice!
It indeed great improvement ;)
Still afraid that if you have 3X the number of particles you're back to the same situation :(
Don't get me wrong This is anyway a great improvement. :geek:
In Cycles i'm able to changes everything In Realtime:
__instances number
__Emitter geometry
__Emitter Color
So if that same behaviour is possible and improve speed We should go this way (Artistically I mean i don't feel restricted with the current cycles behaviour). Maybe we can't access the blender structures like cycles but if there is anything we can mimic by making a given sacrifice maybe it is worth the sacrifice .........
TAO wrote: Fri Feb 19, 2021 3:22 pm Is replacing boost::unordered_map with robin_hood::unordered_flat_map have any benefit in other cases, or do you have any suggestion for using it, if there is i be able to use it in the 3dsmax plugin, or is not necessarily.
It is an hash table with 18,000,000 of entries in this scene, it is not a very common case. I don't think there are many other places where it is worth using. 99% of the scenes will have just <10 entries.
I introduced (partial) multi-thread support in light sources pre-processing so the time required has gone from 35secs to 8secs:
# 8secs light preprocessing:
#   [LuxRays][16.892] EmbreeAccel build time: 19ms
#   [LuxCore][20.773] Light step #1 preprocessing time: 3.88031secs
#   [LuxCore][22.160] Light step #2 preprocessing time: 1.3868secs
#   [LuxCore][22.716] Light step #3 preprocessing time: 0.556359secs
#   [LuxCore][22.716] Light step #4 preprocessing time: 3.48091e-05secs
#   [LuxCore][25.295] Light step #5 preprocessing time: 2.57913secs
#   [LuxCore][25.295] Light total preprocessing time: 8.40269secs
Dade wrote: Mon Feb 22, 2021 10:38 am I introduced (partial) multi-thread support in light sources pre-processing so the time required has gone from 35secs to 8secs:
:shock: :shock:
:shock: :shock:
Post by marcatore »
fantastic job!!
