Page 3 of 7
Re: Compile on MacOS
Posted: Thu Dec 05, 2019 9:38 am
u3dreal wrote: Thu Dec 05, 2019 1:58 am
OK now i'm confused ... does pyluxcore need to be linked against OpenImageDenoise ??? I guess not since it works without
It does but it his linked against LuxCore library and LuxCore library is linked against Intel Oidn so you may be looking in the wrong link step.
Posted: Thu Dec 05, 2019 5:19 pm
by u3dreal
Oh i should n't assume things i don't know
But files get copied now .... only OIDN lib is still with it's real path on otool -L of pyluxconsole .
Alll other are @rpath ... i really wonder where that happens ??? and where does it happen for lucoreui ?
not link library but link directory
Posted: Thu Dec 05, 2019 6:08 pm
by u3dreal
strange it works for OIIO but not for OIDN ...
otool -L luxcoreui
luxcoreui:
@rpath/libomp.dylib (compatibility version 5.0.0, current version 5.0.0)
/System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa (compatibility version 1.0.0, current version 23.0.0)
/System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL (compatibility version 1.0.0, current version 1.0.0)
/System/Library/Frameworks/IOKit.framework/Versions/A/IOKit (compatibility version 1.0.0, current version 275.0.0)
/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation (compatibility version 150.0.0, current version 1560.12.0)
/System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo (compatibility version 1.2.0, current version 1.5.0)
@rpath/libembree3.3.dylib (compatibility version 3.0.0, current version 3.0.0)
/Users/drquader/Documents/GitHub/macos/MacOSCompileDeps/macos/lib/libOpenImageDenoise.0.dylib (compatibility version 0.0.0, current version 1.1.0)
@rpath/libtbb.dylib (compatibility version 0.0.0, current version 0.0.0)
/usr/lib/libz.1.dylib (compatibility version 1.0.0, current version 1.2.11)
/System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL (compatibility version 1.0.0, current version 1.0.0)
@rpath/libOpenImageIO.1.8.dylib (compatibility version 1.8.0, current version 1.8.11)
/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 400.9.4)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1252.200.5)
/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit (compatibility version 45.0.0, current version 1671.10.106)
/System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics (compatibility version 64.0.0, current version 1247.4.1)
/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation (compatibility version 300.0.0, current version 1560.12.0)
/usr/lib/libobjc.A.dylib (compatibility version 1.0.0, current version 228.0.0)
same for pyluxcore,so and luxcoreconsole
otool -L lib/pyluxcore.so
lib/pyluxcore.so:
Where the hell does this @rpath thing happen in the makefiles ????
Posted: Thu Dec 05, 2019 8:03 pm
u3dreal wrote: Thu Dec 05, 2019 6:08 pm
May be, it is here:
https://github.com/LuxCoreRender/LuxCor ... cmake#L199
Posted: Thu Dec 05, 2019 11:17 pm
by u3dreal
Still don't get why it's not done with oidn
can you explain this file ? what's it for ?
https://github.com/LuxCoreRender/LuxCor ... ymbols.map
but even when i add oidn there is does not work
Posted: Fri Dec 06, 2019 10:03 pm
by u3dreal
OK let's forget about all that static ! linking .
I found a tool that collects all the libs and patches the exe accordingly. It's called dylibbundler.
https://github.com/auriamg/macdylibbundler
So I have working LuxCoreUi_2.3alpha0.zip and BlendLuxCore_2.3alpha0.zip here an my Desktop. checked with the "clean" mac.
Still unsure about luxcoreconsole since we would have to publish it with a lib-subfolder.
I'll post links on my website soon.
Posted: Fri Dec 06, 2019 11:21 pm
by u3dreal
OK Files can be found here
http://q3de.com/research/luxcorerender-for-osx-10-13/
would you mind me making a new post in news section ? So people will try it.
cheers u3dreal
Re: Compile on MacOS 10.13
Posted: Sat Dec 07, 2019 10:03 am
I created a post in News section:
viewtopic.php?f=9&t=1599
You may want also to write a post with the news in this thread:
https://blenderartists.org/t/luxcoreren ... 183292/101
Posted: Sat Dec 07, 2019 12:57 pm
by u3dreal
Done .... ssooooo now for a 2.2.Release ??
It seems to be pretty stable... rendered over night for 6 h and everythign seems fine ..... scales great on my xenon 6 core ...
using almost 1.200 % of CPU.
Posted: Sat Dec 07, 2019 1:54 pm
u3dreal wrote: Sat Dec 07, 2019 12:57 pm
There is a tag in Git for v2.2 ("luxcorerender_v2.2") if you extract the sources, you can compile the v2.2 but it may a bit a waste of time (the sources were using some older version of the libraries so it may be not a trivial task to compile the v2.2 because of dependencies: you may have to compile more stuff). It may be better to focus on v2.3 and the hopefully soon to be released beta1.
