Page 19 of 23
Posted: Fri May 13, 2022 3:04 pm
by Harvester
Hi Dade,
when do you plan to publish a new release compatible with Blender version 3.1, and Python 3.10, of the BlendLuxCore add-on?
Thank you.
Posted: Fri May 13, 2022 3:36 pm
Harvester wrote: Fri May 13, 2022 3:04 pm
Hi Dade,
Thank you.
latest BlendLuxCore daily 2.61alpha is compatible with 3.1 and up to 3.3alpha... what gives
Posted: Fri May 13, 2022 3:37 pm
by MCurto
Hi Dade,
Thank you.
Have a look here:
https://github.com/LuxCoreRender/BlendL ... tag/latest
AFAIK won't work with 3.2 but should cover all the 3.1.x
Posted: Fri May 13, 2022 7:15 pm
by Harvester
Thank you all for your feedback. I did follow the instructions I found in the daily builds and I can confirm that it works with Blender 3.1.2.
I will continue to test it while waiting for an official release.
Posted: Fri May 13, 2022 8:02 pm
It works with every Blender using Python API 3.10.
Although, it's waiting for few pull requests to get in:
- Fix Pointer node
- Update to Fresnel node's custom n,k-values
- clarify readme on blender support status
https://github.com/LuxCoreRender/BlendLuxCore/pulls
Posted: Fri Sep 30, 2022 4:36 pm
by Odilkhan Yakubov
Posted: Sat Oct 01, 2022 6:07 pm
by Odilkhan Yakubov
Posted: Wed Oct 12, 2022 10:57 pm
by TAO
it will be more convenient if you send a pull from your repo to the original repository, so it will be merged with it at the end.
Posted: Thu Dec 15, 2022 8:41 pm
by Odilkhan Yakubov
Posted: Tue Jan 03, 2023 4:40 am
by Odilkhan Yakubov
