Page 16 of 109
Re: PhotonGI cache
Posted: Tue Feb 05, 2019 9:25 pm
by epilectrolytics
B.Y.O.B. wrote: Tue Feb 05, 2019 9:06 pm Not yet.
I think the plan was to make this mostly automatic, determined by roughness - is that already implemented?
No idea - how will automatic roughness work with roughness maps (think PBR material)?
Other question: In Luxcore there is a choice of random or metropolis for photon cast - is metropolis the default in BlendLuxCore?
Re: PhotonGI cache
Posted: Tue Feb 05, 2019 10:01 pm
The photongi settings are defined here: https://github.com/LuxCoreRender/BlendL ... ig.py#L323
Everything not set there is using the default set by LuxCore: https://github.com/LuxCoreRender/LuxCor ... e.cpp#L590
Re: PhotonGI cache
Posted: Tue Feb 05, 2019 10:15 pm
by epilectrolytics
B.Y.O.B. wrote: Tue Feb 05, 2019 10:01 pm The photongi settings are defined here: https://github.com/LuxCoreRender/BlendL ... ig.py#L323
Ok - Metropolis as expected.
Thanks B.Y.O.B. - you guys did a great job implementing this cutting edge stuff!
Re: PhotonGI cache
Posted: Tue Feb 05, 2019 11:38 pm
epilectrolytics wrote: Tue Feb 05, 2019 8:59 pm Dade added some option to exclude glossy materials from indirect cache, is that exposed somwhere?
Not yet.
I reverted the plan at the end and only implemented an On/Off flag because glossy roughness can be textured, so it is variable and pretty much unknown (so I can not implement an automatic setting). So, yup, the material flag should be exposed.
Re: PhotonGI cache
Posted: Tue Feb 05, 2019 11:40 pm
epilectrolytics wrote: Tue Feb 05, 2019 8:53 pm First results are quite sobering, caustic cache doesn't like environmental light:
It is more the usual problem of power balance between sky (very low) and sun (very high): it looks like photons are fired mostly from the sun. Have you tried alternative light strategies ?
Re: PhotonGI cache
Posted: Tue Feb 05, 2019 11:41 pm
zuljin3d wrote: Tue Feb 05, 2019 5:48 pm I tried to tweak radius and photon count, but anyway result not perfect.
Can you post the test scene ? It looks like a good test case.
Re: PhotonGI cache
Posted: Wed Feb 06, 2019 5:53 am
Could the lookup radius be calculated from normal pass in screen space? So, large areas would have larger lookup radius and when approaching edges it would be smaller, maybe at the very edge no photons just pathtracing? Is this a stupid idea?
Or maybe just somehow force more acurate calculation on the edges and corners...
Re: PhotonGI cache
Posted: Wed Feb 06, 2019 11:00 am
lacilaci wrote: Wed Feb 06, 2019 5:53 am Could the lookup radius be calculated from normal pass in screen space? So, large areas would have larger lookup radius and when approaching edges it would be smaller, maybe at the very edge no photons just pathtracing? Is this a stupid idea?
It requires ray differentials and it would be the optimal solution but, unfortunately, we don't have ray differentials.
Re: PhotonGI cache
Posted: Wed Feb 06, 2019 11:03 am
by epilectrolytics
Dade wrote: Tue Feb 05, 2019 11:40 pm It is more the usual problem of power balance between sky (very low) and sun (very high): it looks like photons are fired mostly from the sun. Have you tried alternative light strategies ?
Changing light strategy or importance doesn't change anything.
It looks like the sky is excluded from direct sampling.
It looked normal before you fixed the fireflies (direct hits) for infinite lights.
Here's a file:
caustictest7_LuxCore.zip
(42.98 KiB) Downloaded 319 times
Re: PhotonGI cache
Posted: Wed Feb 06, 2019 11:11 am
by epilectrolytics
I'd like to suggest that the debug option showing the photon map is removed and instead it is always contained as a photon AOV when PhotonGI is activated so that it can be toggled as a channel during the render for inspection.
Also it would be nice to have a percentage count in Blender view during cache building.
