Page 16 of 17
Glossy Transluscent, correctum
Posted: Fri Oct 05, 2018 6:37 am
by FarbigeWelt
Sometimes a step back helps to fix issues.
I ran once again into 0815 issue, normals pointing into the wrong direction as it happens after common extrude.
Why glossy behaves differently regarding specularity if normals are wrong, but who knows?
Still, I think specularity is too good visible even set to 0.007. But then, sun is very bright and the behviour is pretty sure correct.
Glossy TL and Glossy comparison
Test Joined Mesh simple.blend
Test Joined Mesh simple with corrected normals
(675.96 KiB) Downloaded 869 times
Irregular Data Node, GPU Path vs CPU Path
Posted: Fri Oct 12, 2018 7:48 pm
by FarbigeWelt
Intended to help me understand DLC settings, I found a scene setup to visualize differences between CPU Path and GPU Path, not to mention their difference to CPU BiDir.
Instead of using Irregular Data node for Emission of a Matte object, I pluged it into Transparancy of a Glass object with a point lamp inside as base shape for LED bars.
CPU BiDir, CPU or GPU Path, LED with Irregular Data
Caustics from a Cube
Posted: Sun Oct 14, 2018 8:45 pm
by FarbigeWelt
Cube, CPU BiDir, depth 10, 100 Samples, 49m, denoised 0.25
Acutally I'm looking for settings for an ice cube.
Re: Irregular Data Node, GPU Path vs CPU Path
Posted: Sun Oct 14, 2018 10:14 pm
FarbigeWelt wrote: Fri Oct 12, 2018 7:48 pm Intended to help me understand DLC settings, I found a scene setup to visualize differences between CPU Path and GPU Path, not to mention their difference to CPU BiDir.
A path tracer is not able to transport a point light source across a specular (i.e. glass) surface. You have to use architectural glass. BiDir is able and it is explain the difference.
Posted: Tue Oct 16, 2018 10:28 am
by FarbigeWelt
Dade wrote: Sun Oct 14, 2018 10:14 pm A path tracer is not able to transport a point light source across a specular (i.e. glass) surface. You have to use architectural glass. BiDir is able and it is explain the difference.
Thanks for explanation, Dade.
But it does not explain why DLC circle artifacts are visible with GPU path but not with CPU path.
Posted: Tue Oct 16, 2018 11:43 am
FarbigeWelt wrote: Tue Oct 16, 2018 10:28 am But it does not explain why DLC circle artifacts are visible with GPU path but not with CPU path.
What circle artifacts ? In the posted image :?:
Posted: Tue Oct 16, 2018 1:21 pm
by FarbigeWelt
Dade wrote: Tue Oct 16, 2018 11:43 am
Please have a look at the pictures below Edit in:
viewtopic.php?f=5&t=430&p=6682#p6682
Posted: Thu Oct 18, 2018 8:56 am
FarbigeWelt wrote: Tue Oct 16, 2018 1:21 pm
This is usually the result of some "incorrect" entry (like a light is not visible while it is) in the cache. It can happen if a light is hard to find and, with the default warmup period of only 12 samples, it ends to result always in shadow. The solution is to increase the "lightstrategy.entry.warmupsamples" parameter up to the point artifacts disappear.
CPU GPU Path
Posted: Mon Nov 12, 2018 7:34 am
by FarbigeWelt
Point Lamp, default w,r,g,b
Glass, rough 1.2
Text matte, emission: 1,10,5
Because of noise level and different distribution of noise (why, it is the same seed?) I smoothed the imgages with a gauss filter.
One can see there is not much difference between CPU and GPU path for this simple scene if its renders are smoothed.
Noise, Path and BiDir or what are Samples?
Posted: Tue Dec 11, 2018 7:16 am
by FarbigeWelt
If I need 7000 path samples to achieve a similar result I get wth 100 BiDir samples, what is sample count for?
Three Monkeys and their Noise, openCL study
The Monkeys and their Noise, indirect only, clamped, HD, BiDir, 100 samples, 15min, BiDir one shot
Indirect Light ,denoiser.zip
Indirect Light, denoiser
(235.13 KiB) Downloaded 836 times
