Page 15 of 92
Re: BlendLuxCore Development
Posted: Fri Jan 26, 2018 8:16 am
by Asticles
yes!
Posted: Fri Jan 26, 2018 10:11 am
Hi B.Y.O.B ! want to make a suggestion about node tree. can you make a link between material name and material nodetree name so their always share the same name ?
Posted: Fri Jan 26, 2018 11:10 am
Thanks for reminding me.
I added a handler that checks if node tree names are out of sync and syncs them if needed:
https://github.com/LuxCoreRender/BlendL ... 2831f9b54f
Seems to work pretty well so far.
Posted: Sat Jan 27, 2018 8:35 am
Thanks B.Y.O.B ! I'm bit ashamed to ask you more But .......................Hmmm !
please if you have a bit more time can you exposed the
Area light spread angle also i've notice that there isn't setting to control
Lamp shadow smootness ?
Posted: Sat Jan 27, 2018 10:24 am
Sharlybg wrote: Sat Jan 27, 2018 8:35 am
can you exposed the Area light spread angle
Sure.
i've notice that there isn't setting to control Lamp shadow smootness ?
Shadow smoothness is controlled by the size of the lamp. You can make area lights larger or raise the sun radius.
However, point lights and spot lights will always create perfectly sharp shadows.
Posted: Sat Jan 27, 2018 10:37 am
B.Y.O.B. wrote: Sat Jan 27, 2018 10:24 am
It may be worth to add the support for a new "radius" parameter for point and spot lights
Posted: Sat Jan 27, 2018 11:02 am
Sure.
Dade wrote: Sat Jan 27, 2018 10:37 am
Exuse me typo error want to say can't control
Point light shadow.
Thank you anyway.
Posted: Sat Jan 27, 2018 11:41 am
Done. On the way I also unified the support for IES files, so all lights where it's possible to use IES files do now support them (point lights, area lights, meshlights).
Could be useful, yes.
Posted: Sun Jan 28, 2018 1:28 pm
by acasta69
it seems that rotate values in texture 3D mapping node are not effective: for whatever value I get the same result.
Translate and scale work properly.
I am using build and addon from yesterday with Blender 2.79a RC.
A test scene is attached.
Posted: Sun Jan 28, 2018 9:08 pm
