Sorry yesterday i had problems with my connection. I try this and i come back.TAO wrote: Thu Nov 28, 2019 4:34 pm Thank you to mention that, so it can be different in different PCs.
I'm working on that, but as i don't have any issue on my pc is a bit hard to fix it.
Please try this build and inform me if the issue is solved.
some options in this build may not work as it supposes to.
also, 2 more shaders add to this build and you can test new shaders too.
http://3dfine.com/down/lux/LuxCoreMax-v0.0.3.zip
another thing, if 3dsmax crashes on start, i may accidentally remove tbb.dll in the installer so just copy this http://3dfine.com/down/lux/tbb.dll into 3dsmax root and you should be good to go.
Well, I solved the decimal problem on 3DsMAx. I have a new message of eurrorTAO wrote: Thu Nov 28, 2019 4:34 pm Thank you to mention that, so it can be different in different PCs.
the crash at the opening of the material editor is still
What was the problem with the decimal point, is that all about your windows language options?Dexter wrote: Fri Nov 29, 2019 6:47 pm Well, I solved the decimal problem on 3DsMAx. I have a new message of error
What are your default windows language anyway ?
Also, can you try one of the sample scenes in the last posts, just to be sure?
I have seen that error message before but I can't remember what was about.
Yes it is Windows language options. I tried the DanishWood scene. the rendering works but the material editor still crashTAO wrote: Fri Nov 29, 2019 9:24 pmWhat was the problem with the decimal point, is that all about your windows language options?Dexter wrote: Fri Nov 29, 2019 6:47 pm Well, I solved the decimal problem on 3DsMAx. I have a new message of error
and also can you try one of the sample scenes in the last posts, just to be sure.
Can you send me a screenshot for the Material editor problem or there is not any message?
Sometimes it happens that the editor window appears, but all the materials are black and when I click on them to modify , 3dsmax crashTAO wrote: Fri Nov 29, 2019 9:42 pm Can you send me a screenshot for the Material editor problem or there is not any message?
That's really strange, do you have any special materials/shaders/textures or renderers.
I try LuxCore with standard/vray/maxwel/arnold/corona shaders and it works fine.
It may be something related to special shaders or even language.
What is this parameters, i can't see that in material editor?
Hi there, hope you all doing great guys .
I am still on the first version that you upload it TAO (LuxCoreMax-v0.0.2.zip) , didn't updated it yet.
I went to the old scenes and found out also this problem
2 Problems :
- the material editor is working but all black, Luxcore materials and Standard materials.
- the two options for ( Samples limit ) and ( Refresh time ) don't work.
The scene renders fine though. This is for all the scenes (DanishMood.zip)(Depth.zip)(LightEmmision.zip)
2 Problems :
first, check if the material editor set to LuxMaxCore in the renderer options.
if it does not work try to update to the new version and update material previews.
if it doesn't working again let me know.
Thank you.
Thank you.
