Page 12 of 32
Re: OpenImageDenoise
Posted: Sun Feb 03, 2019 11:54 am
alpistinho wrote: Sun Feb 03, 2019 11:29 am I've set-up a second image pipeline but it doesn't change the image in any way, even though it becomes very slow and something is happening.
In their example, they check for errors after the filter is executed, not before:
https://github.com/OpenImageDenoise/oid ... pi-example
When we did the BCD integration, we started luxcoreui with
-D screen.tool.type IMAGE_VIEW
So the image only updates every 4 seconds.
Also, you have to open "Window -> Film Outputs editor", look for your OIDN-imagepipeline and click "Show". This will trigger the imagepipeline for the first time.
Then you have to resize the new window.
You can re-run the imagepipeline with the "Refresh" button on the top left.
Posted: Sun Feb 03, 2019 12:06 pm
by alpistinho
B.Y.O.B. wrote: Sun Feb 03, 2019 11:54 am In their example, they check for errors after the filter is executed, not before:
The example in the repo itself was executing before. In any case I've put it after the filter execution and it didn't throw anything.
B.Y.O.B. wrote: Sun Feb 03, 2019 11:54 am When we did the BCD integration, we started luxcoreui with
I did that but there are no filters showing on the "Current Film Outputs settings". The log lines I've added indicate that the code is running, however.
[LuxCore][179.756] [IntelOIDNPlugin] Copying Film to output buffer
[LuxCore][183.828] [IntelOIDNPlugin] Copying Film to input buffer
[LuxCore][183.882] [IntelOIDNPlugin] Executing filter
Can you check my configuration file to see if I'm doing something wrong with it?
film.width = 512
film.height = 512
scene.file = scenes/cornell/cornell.scn
#path.photongi.sampler.type = RANDOM
#path.photongi.sampler.type = METROPOLIS
path.photongi.photon.maxcount = 400000
path.photongi.photon.maxdepth = 4
path.photongi.visibility.lookup.radius = 0.15
path.photongi.direct.enabled = 0
path.photongi.indirect.enabled = 1
path.photongi.indirect.maxsize = 400000
path.photongi.indirect.lookup.radius = 0.075
path.photongi.caustic.enabled = 0
#path.photongi.debug.type = showdirect
#path.pathdepth.total = 4
#film.filter.width = 2
#tilepath.sampling.aa.size = 21
#tile.size = 16
#tile.multipass.enable = 1
#tile.multipass.convergencetest.threshold256 = 16
#tile.multipass.convergencetest.threshold.reduction = 0.5
#screen.tiles.converged.show = 1
#screen.tiles.passcount.show = 1
#screen.tiles.notconverged.show = 1
#screen.tiles.error.show = 1
#lightstrategy.type = DLS_CACHE
film.imagepipelines.0.0.type = GAMMA_CORRECTION
film.imagepipelines.0.0.value = 2.2
film.imagepipelines.1.0.type = GAMMA_CORRECTION
film.imagepipelines.1.0.value = 2.2
film.imagepipelines.1.1.type = INTEL_OIDN
#film.imagepipelines.1.0.type = BCD_DENOISER
#film.imagepipelines.1.1.type = GAMMA_CORRECTION
#film.imagepipelines.1.1.value = 2.2
#film.imagepipelines.0.0.type = PATTERNS
#film.imagepipelines.0.0.index = 0
#film.outputs.1.type = RGB_IMAGEPIPELINE
#film.outputs.1.index = 0
#film.outputs.2.type = RGB_IMAGEPIPELINE
#film.outputs.2.index = 1
#film.outputs.2.type = MATERIAL_ID_COLOR
batch.haltspp = 5
Posted: Sun Feb 03, 2019 12:13 pm
alpistinho wrote: Sun Feb 03, 2019 12:06 pm film.imagepipelines.1.0.type = GAMMA_CORRECTION
I would put the gamma correction after the denoising step, but otherwise, I can't find anything wrong.
I'll try to compile your branch on my machine.
Posted: Sun Feb 03, 2019 12:18 pm
by alpistinho
B.Y.O.B. wrote: Sun Feb 03, 2019 12:13 pm
I just noticed that I was assuming that the Film would be tonemapped, the filter is even set up for LDR, but maybe that's not true.
Since there is no tonemapper defined, is the input film HDR and luxcoreui just tonemaps before drawing on the screen?
Posted: Sun Feb 03, 2019 12:27 pm
alpistinho wrote: Sun Feb 03, 2019 12:18 pm
A normal image pipeline has a tone mapper plugin at some point. The denoiser should be the very first plugin in an image pipeline and it will receive the image in HDR format.
Something like:
film.imagepipelines.1.0.type = INTEL_OIDN
film.imagepipelines.1.1.type = TONEMAP_LINEAR
film.imagepipelines.1.1.scale = 1.0
film.imagepipelines.1.2.type = GAMMA_CORRECTION
film.imagepipelines.1.2.value = 2.2
Posted: Sun Feb 03, 2019 1:10 pm
by alpistinho
Dade wrote: Sun Feb 03, 2019 12:27 pm
Something like:
I've set the filter to HDR and used your suggestion, but saw no change.
I've then changed some data structures to mimic exactly what they're doing on the documentation and while the image does not look denoised, it is different. It has some weird stripe pattern :lol:
Posted: Sun Feb 03, 2019 1:26 pm
alpistinho wrote: Sun Feb 03, 2019 1:10 pm It has some weird stripe pattern :lol:
The problem is in this kind of loop:
for (u_int i = 0; i < pixelCount; i += 3) {
        color[i] = pixels[i].c[0];
        color[i + 1] = pixels[i].c[1];
        color[i + 2] = pixels[i].c[2];
It should be something like:
for (u_int i = 0; i < pixelCount; ++i) {
        const i3 = i * 3;
        color[i3] = pixels[i].c[0];
        color[i3 + 1] = pixels[i].c[1];
        color[i3 + 2] = pixels[i].c[2];
Posted: Sun Feb 03, 2019 1:36 pm
by alpistinho
Dade wrote: Sun Feb 03, 2019 1:26 pm
        const i3 = i * 3;
Thanks Dade!
Sorry for the stupid mistake, it's working now =)
Posted: Sun Feb 03, 2019 1:47 pm
by alpistinho
Is there support for imagepipeline plugins to receive multiple films as input?
Looking at the ImagePipelinePlugin class it seems there is not, should it be extended to receive multiple Films?
EDIT:
I guess I could also hardcode the IntelOIDN class to calculate the needed AOV's internally
Posted: Sun Feb 03, 2019 1:53 pm
alpistinho wrote: Sun Feb 03, 2019 1:47 pm Is there support for imagepipeline plugins to receive multiple films as input?
What do you mean ? A film can have one or more image pipelines and each image pipeline can have any number of plugins. So if you use the Oidn plugin multiple times, there will be multiple/different instances of your class and each one will be called with a different film (so I assume the answer to your question is no).
