Re: PhotonGI cache
Posted: Thu Sep 12, 2019 12:23 pm
Thank you!
Thank you!
I like the idea of the control over the number of bounces before using PGI cache.lacilaci wrote: Wed Sep 11, 2019 4:55 pm I have this idea that might be a bit stupid but maybe not:
Would it be possible to control after how many bounces is photongi used? Maybe this would help with some reflection artifacting or leaks?
So maybe have 1 or 2 bounces brute force and afterwards sample from cache(a control exposed to the user).
The reason is that sometimes luxcore performs well in interior even without photongi but some areas are a bit "too deep" in terms of gi so they could benefit from photongi. However enabling cache might bring some artifacting even to areas which were ok and fast before. So I have to pick between artifacts and speed...
In my head I think this could help protect areas exposed to few bounces but still give speedup for hard to reach areas.
hm, never tried such high threshold..provisory wrote: Fri Sep 13, 2019 9:47 pmI like the idea of the control over the number of bounces before using PGI cache.lacilaci wrote: Wed Sep 11, 2019 4:55 pm I have this idea that might be a bit stupid but maybe not:
In the meantime you could try to enable Add Light Tracing with Glossiness Threshold: 1.
According to my tests it helps to illuminate hard to reach areas. After all PGI uses Light Tracing too.
Cons: doesn't work with Matte (but works with Glossy or Disney with max. roughness) and darkens speculars (without PSR)
What are you using as glossy roughness and PGI roughness threshold ?marcatore wrote: Fri Aug 14, 2020 12:09 pm Is it normal? Isn't it possible to caching more with glossy materials?
This is the expected behavior:marcatore wrote: Fri Aug 14, 2020 12:24 pm higher material roughness value , more red image
as soon as I go little over the PGI glossiness threshold, the image becomes more blue.
