Page 11 of 20
Re: Path Space Regularization (aka the solution to SDS paths)
Posted: Mon Sep 16, 2019 2:59 pm
to get some caustics going in my main scene I have to start with some incredible values for scale, like 10000 so I guess those parameters are very scene dependant...?
well.. you can't see what is going on in the pool but it got close to proper brightness, even pinacollada is no longer black(though still wrong)
Posted: Mon Sep 16, 2019 3:53 pm
lacilaci wrote: Mon Sep 16, 2019 2:59 pm
Distance from the camera is one of the factors so it matters in a scene of 1m Vs 1Km
Posted: Mon Sep 16, 2019 3:59 pm
lacilaci wrote: Mon Sep 16, 2019 2:07 pm
clamping seem to skew the results even though it shouldn't affect lighttracing
But are you using GPU rendering (no one has yet written the support for PSR) ? Because clamping is disabled for light tracing on CPU (
https://github.com/LuxCoreRender/LuxCor ... d.cpp#L151).
Mmm, I have the feeling you are using a clamping value extremely smaller of what should be and it is not the light tracing to "explode" but it is eye tracing to go boom: try to do a rendering disabling PSR and Hybrid, does still happen ?
Posted: Mon Sep 16, 2019 4:07 pm
Dade wrote: Mon Sep 16, 2019 3:59 pm
I did use opencl yes... I can't do more testing now ,but I will play around with cpu and different settings in the morning and post results here.
Posted: Mon Sep 16, 2019 9:14 pm
by Fox
I'm using the hetero volume type water in pool test scene, and there is huge speed increase when i roll back this commit:
https://github.com/LuxCoreRender/LuxCor ... aed3bf5cfb
Water Material
Hetero
Multi
Step 50cm
Steps 32
abs
0.1882334886 0.0864110145 0.005475
inverted to T for Blender exporter: 0.8117665114 0.9135889855 0.994525
sss
0.18804175 0.08702118 0.14913043
g
0.929 0.910 0.945
cauchy A 1.326203018904
cauchy B 0.002152008167
Posted: Tue Sep 17, 2019 5:03 am
ok so this is cpu only (looks same with clamped or unclamped rendering)
so the forever darkening is present always...
But I wouldn't be sure if that's the PSR fault. I think it's either volumes or glass rendering that's causing this.
Look at this example:
PSR
without PSR
the sharp outer ring only appears when using PSR(or bidir) but it never disappears or get weaker, why would psr behave differently here?
Posted: Tue Sep 17, 2019 5:43 am
hm.. tried over 2000 samples in a mirror scene to see if sds will disappear and they do. (CPU)
Posted: Tue Sep 17, 2019 7:25 am
So it is not related to clamping ? I assume your speed parameter is too low (i.e. speed is too high) but I can not say without a test scene.
Posted: Tue Sep 17, 2019 7:40 am
Could it be that the problem is related to bump mapping? In Dade's pool, the mesh surface is displaced, while lacilaci's water surface seems to make use of bump mapping.
Posted: Tue Sep 17, 2019 8:37 am
Oh, fu@k, I had an uninitialized variable in Metropolis code used by PSR (i.e. it could start with random values). This explain the very odd "0.99999997 Vs 0.99999998" problem, now smaller values works fine too (i.e. for faster sharpening).
