Page 2 of 3
Re: Crash with small spread angles
Posted: Sat Feb 10, 2018 12:25 pm
by lighting_freak
I've tried to replace the circle with a square plane. (Edge size 2mm)
It should be 2 tris only, am I right? It's still crashing while using angles below 20 degrees.
BR
Posted: Sat Feb 10, 2018 12:53 pm
lighting_freak wrote: Sat Feb 10, 2018 12:25 pm
It should be 2 trial only, am I right? It's still crashing while using angles below 20 degrees.
It is still too small, just use a laser light source or a spot light.
Posted: Sun Feb 11, 2018 11:06 am
by lighting_freak
with "laser light source" you're meaning the "Area" option, or did I miss anything in new lux core?
- light_sources.JPG (10.89 KiB) Viewed 9118 times
BR
Posted: Sun Feb 11, 2018 11:14 am
lighting_freak wrote: Sun Feb 11, 2018 11:06 am
BR
This:
Posted: Sun Feb 11, 2018 7:55 pm
by lighting_freak
Hi
This:
Sure...
One more question, why is the amount of emitted energy depending on the spread angle?
In my mind each surface element (tri) emits light dependent on it size (area) but not the direction.
Thanks.
BR
Posted: Sun Feb 11, 2018 8:42 pm
lighting_freak wrote: Sun Feb 11, 2018 7:55 pm
At the moment, theta parameter just "cut" the emitted light (like if it was obstructed), it doesn't increase the emitted light when you decrease the angle. Yes, it would be more correct to keep the total emitted power constant.
Posted: Mon Feb 12, 2018 6:57 pm
by lighting_freak
does that mean, that I don't get 1 lumens output if I enter 1 lumen (1 watt and 1 efficiacy) and an angle smaller 90deg?
BR
Posted: Mon Feb 12, 2018 8:09 pm
lighting_freak wrote: Mon Feb 12, 2018 6:57 pm
Yup, you get less. You should get (1.0 - cos(theta)) lumen.
Posted: Tue Feb 13, 2018 5:57 am
by lighting_freak
This points directly to the next question... how is the energy management in area and laser light sources?
How do you solve this in volume emitters?
It might be to early to push functionality requests to you but do you think it might be possible to change the material emitter into an energy consistent one?
BR
Posted: Tue Feb 13, 2018 10:06 am
lighting_freak wrote: Tue Feb 13, 2018 5:57 am
It is correct as far as I know, only theta is an after tough. Theta is bit a problem because it is like defining 3 types of different light sources:
- Theta = 0 => it is like a laser light source
- 0 < Theta < 90 => it is light a spot light source
- Theta = 90 => it is normal area light source
The sampling used in the 3 cases is different so not updating energy management was a short cut for theta < 90.
It is considered a set of point lights with the specified parameters (and at the moment, it is only a scalar RGB value without power/efficiency).
Yes, I'm going to sort out the energy consistency with theta (everything else should be consistent as far as I know).
