Page 2 of 2
Re: In Blender, a sudden change of colours is happening in my render. Why?
Posted: Fri Dec 28, 2018 8:13 pm
by wasd
Dade wrote: Fri Dec 28, 2018 4:02 pm
I'm looking at your scene and it works fine if I replace the "mattetranslucent" material with matte
I see no point in replacing mattetranslucent with matte, the problem is with translucent materials.
It is pretty much impossible to check if the hundreds of leafs are "well formed" for me, can you reproduce the same problem with just a single cube ?
Not right now. But in every scene I have that problem. Maybe camera volume is not bugged, it is them practically useless.
That's a perfectly formed sphere. Beside tree:
By itself:
- leaf-3.png (9.53 KiB) Viewed 6154 times
Posted: Fri Jan 18, 2019 4:56 am
by happysmash27
After doing CPU rendering after an update, the change now appears between frames 591 and 592.
Posted: Fri Jan 18, 2019 7:04 am
by happysmash27
Update:
It seems that for some reason, OpenCL kernel compiling suddenly takes an insane amount of time. In other news, however, rendering the same frame does, indeed, give wildly different results on OpenCL and CPU rendering:
Posted: Fri Jan 18, 2019 10:24 am
happysmash27 wrote: Fri Jan 18, 2019 7:04 am
Update:
It looks like an NVIDIA OpenCL driver bug: sometime the break stuff, it has happened already multiple times, you can try to install the latest driver and than go back, looking for a working driver.
Posted: Sat Jan 19, 2019 12:59 am
by happysmash27
I use an AMD RX 480, not a Nvidia card.
Posted: Sat Jan 19, 2019 11:59 am
by wasd
Did you try to disable Auto-Detect Camera Volume?
CPU render
Auto-Detect Camera Volume:
591
592
Camera Volume Disabled:
591
592
It's not some "malformed mesh geometry" problem. What can possibly be "malformed" in a bunch of parallelepipeds?
