Page 2 of 3
Re: Light strategies and importance change lighting
Posted: Mon Dec 10, 2018 5:18 pm
by Racleborg
Here's what you have to do, or could try. Use clamping value of 100 000
I do do use that approach too. The idea of Dade's to be able to just eliminate the fireflies, appeals to me.
I personally just abuse it too much cause I think that something is terribly boken
Maybe I am misunderstanding something here: Isn't Lux based on the idea of using true physical values, in which case if values are not realistic then doesn't that cause a conflict somewhere?
Like I say, I'm a learner so please point me in the right direction.
Posted: Mon Dec 10, 2018 5:23 pm
Racleborg wrote: Mon Dec 10, 2018 5:18 pm
I do hope that luxcore isn't an ideology and all that unbiased bs that simply don't exist. "true" values mean nothing if no one can use them or find them useful. Thing need to look and behave convincing, that's it.
Posted: Mon Dec 10, 2018 5:25 pm
by Racleborg
Ok, thank you for that explanation.
There was no 'bs' intended. I apologise if it seemed that way.
Posted: Mon Dec 10, 2018 5:41 pm
Racleborg wrote: Mon Dec 10, 2018 5:25 pm Ok, thank you for that explanation.
lol I wasnt talking about your post. I'm just an user like you, and I too hope everything is well on track.
Posted: Mon Dec 10, 2018 5:44 pm
lacilaci wrote: Mon Dec 10, 2018 5:23 pm I do hope that luxcore isn't an ideology and all that unbiased bs that simply don't exist. "true" values mean nothing if no one can use them or find them useful. Thing need to look and behave convincing, that's it.
I guess you know the sayings about lies and easily getting tangled up in them.
If you introduce too many tricks in the wrong places, it will get harder and harder with time to keep everything working together.
So, in the short term it might look like a good idea to cheat here and there, but it might hurt you in the long term.
(I'm talking from a programmer perspective here)
I am not against tricks at all, but you always have to weigh the benefits against possible drawbacks in the future.
Posted: Mon Dec 10, 2018 6:16 pm
B.Y.O.B. wrote: Mon Dec 10, 2018 5:44 pm
Of course, everything should be 'based' in real world. But flexibility needs to be present. Honestly this isn't a difficult topic that needs reinventing wheel. look at popular solutions and you know what works. Like I said most of the things present work like a charm in luxcore and need some little tweaks at most(bcd is an exception from hell) so whatever you guys do I believe it's for the best. I'm only arguing here for certain ideas to be considered, that's all.
Posted: Mon Dec 10, 2018 6:22 pm
by Racleborg
I quite like BCD. What's wrong with it?
Posted: Mon Dec 10, 2018 6:31 pm
Racleborg wrote: Mon Dec 10, 2018 6:22 pm
It's causing paranoya and depression. Should be avoided if possible
Posted: Mon Dec 10, 2018 6:44 pm
by Racleborg
I meant technically....or at least as technical as possible for a layman to understand ;)
Posted: Mon Dec 10, 2018 6:59 pm
Racleborg wrote: Mon Dec 10, 2018 6:44 pm
Ok, so to put ot shortly.
1.Performance, which is the least of it's problems is insane. No previews possible using BCD in any type of production workflow (Granted, Dade claimed this one could be solved by using bcd on opencl.
2.Resources, I can't render 4K render on 6GB gpu once bcd is enabled, and that's mostly pc and mobile viewing, high res prints are out of question probably even on a 11gb gpu.
3.Quality, it requires pretty near clean result and defined textures in render so that it won't destroy details since there is no extra passes for texture detail preservations nor any feature detection etc.
In summary the denoiser is near useless compared to nvidia denoiser which is not even that great aside previewing purposes and it couldn't even be compared to what popular renderers denoisers have to offer for final rendering.
I don't know if BCD is being actively worked on and is evolving and may actually become some cool thing to have so do take it as only my current opinion. But compared how well other things work in luxcore it feels like this denoiser is doing more damage than help
Still, just my opinion. You said you like it, I have no idea why, but who am I to tell you what to like. :)
