Re: How to imitate real world materials
Posted: Tue Nov 20, 2018 4:19 pm
Hello,
No, my intension is to directly control each of the elements. All elements in transmission should handle transitive properties only, etc.
I thought that settings like diffuse colour = black means that I reduced the reflected amount of light in glossy translucent tab down to 0.
In case of attached blend file should create a very narrow glossy reflection (controlled by reflection frame) and a very narrow transmission (controlled by transmission frame). The ratio between is 50/50, no absorption.
The light source is also a very narrow, little downward pointing beam. I assumed to see a stripe in reflectance (yes, I do) and transmission (no, I don't).
Also simple node setup with glossy translucent material show strong scattering even with low roughness values.
I know it's hard to understand the question... thanks for taking care that much.
BR
BR
