Re: Glass is getting too dark...
Posted: Sat Aug 18, 2018 1:21 am
Am aware... still, the issue here is with the loss of energy when dispersion is used - makes it unusable with clamping.Dade wrote: Thu Aug 16, 2018 8:07 pmThat is not even vaguely dispersion.kintuX wrote: Thu Aug 16, 2018 4:27 pmCan simulate dispersion in Cycles with shader nodes, separating RGB chanels using different IORs and adding, summing it back.Dade wrote: Thu Aug 16, 2018 3:00 pm We were talking of the first image, of dispersion and Cauchy's equation: how can be Cycles used as reference if it doesn't support dispersion at all![]()
IMHO, in archviz, product & jewelry viz this is one of those details that either make or break the deal.
Cycles FAKE dispersion:
Maxwell Render 100% dispersion:
Quite much inconsistencies in values among different engines so i'm gonna continue exploring, comparing, searching for optimal solution and post notes/thoughts here. I guess learning & correcting mistakes (fixing bugs) never ends. & Of course, am gonna use LuxCore with proper/better values, yet still do tests with others engines: Indigo, Ocean, Iray, VRay, Octane, RedShift, appleseed, Arnold, Corona, PRMan...
Tho strangest thing, except Cycles, no other engine i know off (even those that claim to simulate physically correct - ground truth) uses multi-scattered GGX model, which in most cases helps a lot in realistic shading. I remember how fast had been implemented in Cycles. But lots of other stuff is missing, so...
... the traveling continues.
Thanks again and keep the genius alive.
