Page 2 of 2
Re: crashes - A heap has been corrupted error
Posted: Tue Nov 30, 2021 9:36 pm
by TAO
Dade wrote: Tue Nov 30, 2021 9:10 pm
TAO wrote: Tue Nov 30, 2021 8:25 pm
I'm not sure, Here is the renderfinal.
void MaxToLux::renderFinal(luxcore::Scene &scene, TimeValue t, Bitmap *tobm, FrameRendParams &frp, HWND hwnd, RendProgressCallback *prog, ViewParams *vp)
It should work, the argument is declared by reference.
I will dig a little bit more maybe I made a mistake in other arguments.
Posted: Tue Nov 30, 2021 10:07 pm
TAO wrote: Tue Nov 30, 2021 9:36 pm
Try to post a debugger stack backtrace of the crash (i.e. where in the Scene destructor is the crash).
Posted: Wed Dec 01, 2021 10:50 am
by TAO
Dade wrote: Tue Nov 30, 2021 10:07 pm
Call stack
error list and other parts showing nothing.
just a critical error number in the output.
start create material: Material_14
========================= Final =======================>1
========================= Final =======================>10
========================= Final =======================>100HairVrRenderNotify::PreRender
The thread 0x29c0 has exited with code 0 (0x0).
The thread 0x1f3c has exited with code 0 (0x0).
The thread 0x30fc has exited with code 0 (0x0).
The thread 0x5500 has exited with code 0 (0x0).
The thread 0x4138 has exited with code 0 (0x0).
The thread 0x3fb4 has exited with code 0 (0x0).
The thread 0x3bec has exited with code 0 (0x0).
The thread 0x564c has exited with code 0 (0x0).
The thread 0x5cdc has exited with code 0 (0x0).
The thread 0x5ac8 has exited with code 0 (0x0).
The thread 0x5538 has exited with code 0 (0x0).
The thread 0x5304 has exited with code 0 (0x0).
The thread 0x4140 has exited with code 0 (0x0).
The thread 0x3b94 has exited with code 0 (0x0).
The thread 0x4358 has exited with code 0 (0x0).
The thread 0x22d4 has exited with code 0 (0x0).
HairVrRenderNotify::PostRender
Helper Nodes deleted: 0
The thread 0x10fc has exited with code 0 (0x0).
The thread 0x5fbc has exited with code 0 (0x0).
Critical error detected c0000374
3dsmax.exe has triggered a breakpoint.
Note, if I had more objects with multi-materials in the scene it is more likely to reach the error. the render itself continues and the problem is when canceling the render.
Posted: Wed Dec 01, 2021 11:45 am
You may need to compile luxcore.dll with debug symbols in order to have readable stack trace of the crash (and know where inside LuxCore it happens).
Posted: Sat Dec 04, 2021 4:51 pm
by TAO
Dade wrote: Wed Dec 01, 2021 11:45 am
Found the issue, it was a wrong number of UV parameters, in 3dsmax UV is a Point3 variable and has 3 values for u,v, and w, as I rewrite all mesh functions I did not notice the difference between the 3dsmax Point3 variable and LuxcoreRender Point2 UV parameters, because of that I had 1/3 more value than UV input should have, so base on an object and UV setup I may or may not face the issue.
The problem is solved now.
is there any way to add w in UV for luxcore as maybe 3dsmax users what to use it?
Posted: Sat Dec 04, 2021 7:22 pm
TAO wrote: Sat Dec 04, 2021 4:51 pm
You could couple 2xUVs (i.e. multiple UV sets) to store up to 4 values for each vertex but it sounds ultra complicated.
Posted: Sat Dec 04, 2021 7:26 pm
by TAO
Dade wrote: Sat Dec 04, 2021 7:22 pm
No problem it's not that usable feature in 3dsmax, by the way, is there any limitation to the number of UV channels in LuxCoreRneder?
Posted: Sat Dec 04, 2021 9:54 pm
TAO wrote: Sat Dec 04, 2021 7:26 pm
8 channels:
https://github.com/LuxCoreRender/LuxCor ... pes.cl#L21
