Re: [CRASHING] Simples scene crashing on RTX2070
Posted: Thu Apr 15, 2021 2:36 pm
Try to check the %tmp% directory for a crash log. It has the name "<name-of-blendfile>.crash.txt" and usually contains a stacktrace that might help us.
I don't even know what that means. heheAndreasResch wrote: Thu Apr 15, 2021 1:19 pm Have you tried starting Blender in debug mode with "blender -d"? Maybe the console window gives some insight into the issue.
This is what the file shows:B.Y.O.B. wrote: Thu Apr 15, 2021 2:36 pm Try to check the %tmp% directory for a crash log. It has the name "<name-of-blendfile>.crash.txt" and usually contains a stacktrace that might help us.
# Blender 2.92.0, Commit date: 2021-02-24 16:25, Hash 02948a2cab44
Read library: 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Arc__Light.blend', 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Arc__Light.blend', parent '<direct>' # Info
Read library: 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\B-Home_Pack_1.blend', 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\B-Home_Pack_1.blend', parent '<direct>' # Info
Read library: 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\BB_SOFA_C2.blend', 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\BB_SOFA_C2.blend', parent '<direct>' # Info
Read library: 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Golden_Glass_Table.blend', 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Golden_Glass_Table.blend', parent '<direct>' # Info
Read library: 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Interior_Plant_1.blend', 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Interior_Plant_1.blend', parent '<direct>' # Info
Read library: 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Straight_Curtain.blend', 'C:\Users\augus\LuxCoreOnlineLibrary_data\model\Straight_Curtain.blend', parent '<direct>' # Info
bpy.ops.object.select_all(action='DESELECT') # Operator
bpy.context.space_data.shading.type = 'SOLID' # Property
Saved "Luxcore teste live.blend" # Info
bpy.ops.outliner.select_box(tweak=True, xmin=100, xmax=197, ymin=622, ymax=809) # Operator
bpy.ops.outliner.item_activate(extend=False, deselect_all=True) # Operator
bpy.ops.outliner.select_box(tweak=True, xmin=121, xmax=202, ymin=605, ymax=816) # Operator
bpy.context.space_data.shading.type = 'RENDERED' # Property
# backtrace
Exception Record:
ExceptionCode : UNKNOWN EXCEPTION
Exception Address : 0x00007FFC8559D759
Exception Module : KERNELBASE.dll
Exception Flags : 0x00000001
Exception Parameters : 0x4
Parameters[0] : 0x0000000019930520
Parameters[1] : 0x000000D73F7FF4B8
Parameters[2] : 0x00007FFBE9264E58
Parameters[3] : 0x00007FFBE85A0000
Stack trace:
KERNELBASE.dll :0x00007FFC8559D6F0 RaiseException
VCRUNTIME140.dll :0x00007FFC75596180 CxxThrowException
pyluxcore.pyd :0x00007FFBE86EC5A0 boost::serialization::void_cast_register<slg::MistPlugin,slg::ImagePipelinePlugin>
pyluxcore.pyd :0x00007FFBE8908250 PyInit_pyluxcore
pyluxcore.pyd :0x00007FFBE8719170 boost::archive::detail::pointer_oserializer<boost::archive::binary_oarchive,luxrays::SpectrumGroup>
ucrtbase.dll :0x00007FFC85491B20 configthreadlocale
KERNEL32.DLL :0x00007FFC86E57020 BaseThreadInitThunk
ntdll.dll :0x00007FFC879E2630 RtlUserThreadStart
Threads:
Thread : 00004300
ntdll.dll :0x00007FFC87A2D750 NtWaitForMultipleObjects
KERNELBASE.dll :0x00007FFC855C0C50 WaitForMultipleObjectsEx
pyluxcore.pyd :0x00007FFBE8653CF0 boost::serialization::singleton<boost::archive::detail::extra_detail::guid_initializer<slg::RenderS
pyluxcore.pyd :0x00007FFBE85B7CA0 boost::serialization::singleton_module::is_locked
pyluxcore.pyd :0x00007FFBE88D8F20 boost::serialization::singleton<boost::archive::detail::extra_detail::map<boost::archive::binary_oa
python37.dll :0x00007FFBF7B9E3F0 PyType_GenericNew
python37.dll :0x00007FFBF7B66190 PyFrame_GetLineNumber
python37.dll :0x00007FFBF7C7A1B0 PyThread_GetInfo
python37.dll :0x00007FFBF7C0E490 PyEval_EvalFrameDefault
python37.dll :0x00007FFBF7B464E0 PyObject_Call
blender.exe :0x00007FF7056E4C40 bpy_class_call
blender.exe :0x00007FF7056CC660 engine_view_draw
blender.exe :0x00007FF70539DBB0 external_draw_scene
blender.exe :0x00007FF705366AD0 drw_engines_draw_scene
blender.exe :0x00007FF705363460 DRW_draw_render_loop_ex
blender.exe :0x00007FF7053644C0 DRW_draw_view
blender.exe :0x00007FF705B32770 view3d_main_region_draw
blender.exe :0x00007FF70570BC20 ED_region_do_draw
blender.exe :0x00007FF7052ABBF0 wm_draw_window_offscreen
blender.exe :0x00007FF7052ABA40 wm_draw_window
blender.exe :0x00007FF7052AB540 wm_draw_update
blender.exe :0x00007FF7052884D0 WM_main
blender.exe :0x00007FF704F79C70 main
blender.exe :0x00007FF709483468 __scrt_common_main_seh
Thread : 0000199c
ntdll.dll :0x00007FFC87A2CC80 ZwWaitForSingleObject
KERNELBASE.dll :0x00007FFC8558A2C0 WaitForSingleObjectEx
blender.exe :0x00007FF708A801D0 IlmThread_2_4::Semaphore::wait
blender.exe :0x00007FF708A7F9A0 IlmThread_2_4::ThreadPool::numThreads
blender.exe :0x00007FF708A80650 std::_LaunchPad<std::unique_ptr<std::tuple<void (__cdecl IlmThread_2_4::Thread::*)(void) __ptr64,Il
blender.exe :0x00007FF707C759C0 std::_Pad::_Call_func
Thread : 00002b84
Thread : 00003774
Thread : 00003ca0
Thread : 0000517c
Thread : 00003e6c
Thread : 00001370
Thread : 00003e38
Thread : 0000272c
ntdll.dll :0x00007FFC87A305F0 ZwWaitForAlertByThreadId
ntdll.dll :0x00007FFC879F3EF0 RtlSleepConditionVariableSRW
KERNELBASE.dll :0x00007FFC855DBA60 SleepConditionVariableSRW
MSVCP140.dll :0x00007FFC61AEBA70 _crtSetThreadpoolWait
MSVCP140.dll :0x00007FFC61AC2650 std::_Winerror_message
OpenAL32.dll :0x00007FFC003E5670 alcGetInteger64vSOFT
OpenAL32.dll :0x00007FFC003D0080 alGetError
Thread : 000005e0
Thread : 00004a0c
Thread : 000042e4
combase.dll :0x00007FFC85F8A880 RoGetServerActivatableClasses
Thread : 00004ba8
ntdll.dll :0x00007FFC87A30650 NtWaitForWorkViaWorkerFactory
ntdll.dll :0x00007FFC879E2680 TpReleaseCleanupGroupMembers
Thread : 000049f4
Thread : 0000112c
nvoglv64.dll :0x00007FFBEA17F9B0 DrvValidateVersion
nvoglv64.dll :0x00007FFBE9F0CC3D Symbols not available
Thread : 00004858
KERNELBASE.dll :0x00007FFC855C0C30 WaitForMultipleObjects
nvoglv64.dll :0x00007FFBEA1B8D50 DrvPresentBuffers
nvoglv64.dll :0x00007FFBEA5D2C90 vk_icdNegotiateLoaderICDInterfaceVersion
Thread : 0000374c
win32u.dll :0x00007FFC850DA0F0 NtUserMsgWaitForMultipleObjectsEx
USER32.dll :0x00007FFC875A06F0 MsgWaitForMultipleObjectsEx
Thread : 00004bb8
Wacom_Tablet.dll :0x00007FFC56A58FE9 WTOpenW
Thread : 00002910
tbb.dll :0x00007FFC6C2319C0 tbb::thread_bound_filter::try_process_item
Thread : 0000303c
Thread : 00004484
Thread : 00004b18
Thread : 00004bd8
Thread : 00004f24
Thread : 00004d68
mswsock.dll :0x00007FFC848C80FC Symbols not available
Thread : 00002054
ntdll.dll :0x00007FFC87A2D280 NtDelayExecution
KERNELBASE.dll :0x00007FFC855BD7B0 SleepEx
python37.dll :0x00007FFBF7AF8B60 PyTraceMalloc_GetTraceback
python37.dll :0x00007FFBF7B46EE0 PyMethodDef_RawFastCallKeywords
python37.dll :0x00007FFBF7C13FA0 PyEval_GetFuncDesc
python37.dll :0x00007FFBF7B469C0 PyFunction_FastCallKeywords
python37.dll :0x00007FFBF7B47730 PyObject_Call_Prepend
python37.dll :0x00007FFBF7AF2BA0 PyOS_SigintEvent
python37.dll :0x00007FFBF7C79690 PyThread_init_thread
Thread : 00001920
Thread : 00003200
Thread : 00003b1c
VCOMP140.DLL :0x00007FFC067A2554 vcomp_ordered_loop_end
VCOMP140.DLL :0x00007FFC067A7FB0 vcomp_atomic_div_r8
Thread : 00003a14
Thread : 00002ad4
Thread : 00000508
Thread : 00001de8
Thread : 00002eb0
Thread : 00001b34
Thread : 0000155c
nvcuda64.dll :0x00007FFC62DD6714 Symbols not available
Thread : 00002868
nvcuda64.dll :0x00007FFC62E40D80 cuProfilerStop
nvcuda64.dll :0x00007FFC62DD60E3 Symbols not available
Thread : 00004008
ntdll.dll :0x00007FFC879F4190 RtlSleepConditionVariableCS
KERNELBASE.dll :0x00007FFC855DB9B0 SleepConditionVariableCS
nvcuda64.dll :0x00007FFC62D54A9C Symbols not available
Thread : 000013d4
Thread : 00004bac
Thread : 000047f4
Thread : 0000460c
Thread : 000046d8
Thread : 000045bc
Thread : 00001b7c
Thread : 00004c3c
Thread : 0000349c
Thread : 00002ed0
Loaded Modules :
0x00007FF704E50000 2.9.2.0 blender.exe C:\Program Files\Blender Foundation\Blender 2.92\blender.pdb
0x00007FFC87990000 10.0.19041.844 ntdll.dll
0x00007FFC86E40000 10.0.19041.804 KERNEL32.DLL
0x00007FFC85570000 10.0.19041.804 KERNELBASE.dll
0x00007FFC87580000 10.0.19041.746 USER32.dll
0x00007FFC850D0000 10.0.19041.867 win32u.dll
0x00007FFC6C220000 2019.9.0.0 tbb.dll
0x00007FFC86510000 10.0.19041.746 GDI32.dll
0x00007FFC85360000 10.0.19041.746 gdi32full.dll
0x00007FFC85950000 10.0.19041.789 msvcp_win.dll
0x00007FFC85470000 10.0.19041.789 ucrtbase.dll
0x00007FFC866F0000 10.0.19041.844 SHELL32.dll
0x00007FFC75590000 14.26.28720.3 VCRUNTIME140.dll
0x00007FFC61AB0000 14.26.28720.3 MSVCP140.dll
0x00007FFC85260000 10.0.19041.546 CFGMGR32.dll
0x00007FFC877D0000 10.0.19041.546 WS2_32.dll
0x00007FFC86360000 10.0.19041.746 RPCRT4.dll
0x00007FFC61980000 10.0.19041.844 OPENGL32.dll
0x00007FFC00510000 7.0.0.0 openvdb.dll
0x00007FFC85D30000 7.0.19041.546 msvcrt.dll
0x00007FFC878A0000 10.0.19041.610 ADVAPI32.dll
0x00007FFC85EC0000 10.0.19041.844 combase.dll
0x00007FFC85B40000 10.0.19041.789 sechost.dll
0x00007FFC87450000 10.0.19041.746 ole32.dll
0x00007FFC85DD0000 10.0.19041.546 PSAPI.DLL
0x00007FFBF7700000 58.29.100.0 avformat-58.dll
0x00007FFC85CB0000 10.0.19041.746 SHLWAPI.dll
0x00007FFBEBEA0000 58.54.100.0 avcodec-58.dll
0x00007FFC85B10000 10.0.19041.546 IMM32.dll
0x00007FFC61950000 58.8.100.0 avdevice-58.dll
0x00007FFC54820000 56.31.100.0 avutil-56.dll
0x00007FFC85BE0000 10.0.19041.804 OLEAUT32.dll
0x00007FFC852B0000 10.0.19041.662 bcrypt.dll
0x00007FFC41170000 5.5.100.0 swscale-5.dll
0x0000000070440000 1.0.28.0 libsndfile-1.dll
0x00007FFC003C0000 1.20.1.0 OpenAL32.dll
0x00007FFC2A2D0000 2.0.12.0 SDL2.dll
0x000000006ACC0000 libgmp-10.dll
0x00007FFC802C0000 2019.9.0.0 tbbmalloc_proxy.dll
0x00007FFC86F00000 10.0.19041.844 SETUPAPI.dll
0x00007FFC7DC60000 14.26.28720.3 VCRUNTIME140_1.dll
0x00007FFBF7A40000 3.7.7150.1013 python37.dll
0x00007FFC673A0000 6.10.19041.844 COMCTL32.dll
0x00007FFC61680000 10.0.19041.1 AVIFIL32.dll
0x00007FFC7E340000 10.0.19041.546 VERSION.dll
0x00007FFC837F0000 10.0.19041.867 dbghelp.dll
0x00007FFC60950000 10.0.19041.844 GLU32.dll
0x00007FFC69460000 10.0.19041.546 Secur32.dll
0x00007FFC5C810000 3.5.100.0 swresample-3.dll
0x0000000070680000 libfftw3-3.dll
0x00007FFC58A80000 10.0.19041.1 AVICAP32.dll
0x00007FFC5C7D0000 2019.9.0.0 tbbmalloc.dll
0x00007FFC3D030000 10.0.19041.1 MSVFW32.dll
0x00007FFC6FE80000 10.0.19041.546 WINMM.dll
0x00007FFC5FCE0000 10.0.19041.1 MSACM32.dll
0x00007FFC84F90000 10.0.19041.662 SSPICLI.DLL
0x00007FFC66650000 10.0.19041.1 winmmbase.dll
0x00007FFC862B0000 10.0.19041.746 shcore.dll
0x00007FFC83A00000 10.0.19041.546 kernel.appcore.dll
0x00007FFC82F60000 10.0.19041.844 windows.storage.dll
0x00007FFC84B40000 10.0.19041.662 Wldp.dll
0x00007FFC828C0000 10.0.19041.746 uxtheme.dll
0x00007FFC852E0000 10.0.19041.662 bcryptPrimitives.dll
0x00007FFC85010000 10.0.19041.844 profapi.dll
0x00007FFC87720000 2001.12.10941.16384 clbcatq.dll
0x00007FFC7F720000 10.0.19041.789 MMDevApi.dll
0x00007FFC84E80000 10.0.19041.546 DEVOBJ.dll
0x00007FFC7FB40000 10.0.19041.789 AUDIOSES.DLL
0x00007FFC846D0000 10.0.19041.546 powrprof.dll
0x00007FFC84540000 UMPDC.dll
0x00007FFC82980000 10.0.19041.546 resourcepolicyclient.dll
0x00007FFC859F0000 10.0.19041.867 MSCTF.dll
0x00007FFC6A3F0000 10.0.19041.746 dataexchange.dll
0x00007FFC80BE0000 10.0.19041.746 d3d11.dll
0x00007FFC81B50000 10.0.19041.746 dcomp.dll
0x00007FFC83A20000 10.0.19041.746 dxgi.dll
0x00007FFC7E110000 10.0.19041.746 twinapi.appcore.dll
0x00007FFC7D530000 10.0.19041.844 AppXDeploymentClient.dll
0x00007FFBE9510000 27.21.14.6140 nvoglv64.dll
0x00007FFC80BC0000 10.0.19041.546 WTSAPI32.dll
0x00007FFC84CC0000 10.0.19041.546 msasn1.dll
0x00007FFC7DCB0000 10.0.19041.546 cryptnet.dll
0x00007FFC85100000 10.0.19041.844 CRYPT32.dll
0x00007FFC84AB0000 10.0.19041.546 cryptbase.dll
0x00007FFC85840000 10.0.19041.804 WINTRUST.dll
0x00007FFC83E20000 10.0.19041.546 ntmarta.dll
0x00007FFC78750000 10.0.19041.546 dxcore.dll
0x00007FFC82C70000 10.0.19041.746 dwmapi.dll
0x00007FFC843D0000 10.0.19041.546 WINSTA.dll
0x00007FFC7B6C0000 10.0.19041.844 textinputframework.dll
0x00007FFC824B0000 10.0.19041.746 CoreMessaging.dll
0x00007FFC82100000 10.0.19041.546 CoreUIComponents.dll
0x00007FFC819F0000 10.0.19041.844 wintypes.dll
0x00007FFBF1040000 1.0.5.10 Wintab32.dll
0x00007FFC760E0000 10.0.19041.546 MPR.dll
0x00007FFC56A50000 6.3.42.2 Wacom_Tablet.dll
0x00007FFC5EDC0000 10.0.19041.844 explorerframe.dll
0x00007FFC80910000 7.0.19041.867 propsys.dll
0x00007FFC84A90000 10.0.19041.546 CRYPTSP.dll
0x00007FFC84190000 10.0.19041.546 rsaenh.dll
0x00007FFC7B7C0000 3.7.7150.1013 python3.dll
0x00007FFBF0D70000 _multiarray_umath.cp37-win_amd64.pyd
0x00007FFC69C80000 _multiarray_tests.cp37-win_amd64.pyd
0x00007FFC5AA80000 3.7.7150.1013 _ctypes.pyd
0x00007FFC410E0000 lapack_lite.cp37-win_amd64.pyd
0x00007FFBF0B50000 _umath_linalg.cp37-win_amd64.pyd
0x00007FFC69510000 3.7.7150.1013 _bz2.pyd
0x00007FFC56A10000 3.7.7150.1013 _lzma.pyd
0x00007FFC52C90000 3.7.7150.1013 _decimal.pyd
0x00007FFC66E00000 _pocketfft_internal.cp37-win_amd64.pyd
0x00007FFC2BAF0000 mtrand.cp37-win_amd64.pyd
0x00007FFC5A910000 common.cp37-win_amd64.pyd
0x00007FFC2BAA0000 bounded_integers.cp37-win_amd64.pyd
0x00007FFC64290000 mt19937.cp37-win_amd64.pyd
0x00007FFC3AAD0000 bit_generator.cp37-win_amd64.pyd
0x00007FFC79600000 3.7.7150.1013 _hashlib.pyd
0x00007FFBF0800000 1.1.1.4 libcrypto-1_1.dll
0x00007FFC60930000 philox.cp37-win_amd64.pyd
0x00007FFC5D2E0000 pcg64.cp37-win_amd64.pyd
0x00007FFC5AA60000 sfc64.cp37-win_amd64.pyd
0x00007FFC00320000 generator.cp37-win_amd64.pyd
0x00007FFBF0400000 etree.cp37-win_amd64.pyd
0x00007FFC29B50000 _elementpath.cp37-win_amd64.pyd
0x00007FFC59D80000 3.7.7150.1013 _socket.pyd
0x00007FFC78100000 3.7.7150.1013 select.pyd
0x00007FFC530A0000 3.7.7150.1013 _ssl.pyd
0x00007FFC00270000 1.1.1.4 libssl-1_1.dll
0x00007FFC768D0000 3.7.7150.1013 _queue.pyd
0x00007FFC848C0000 10.0.19041.546 mswsock.dll
0x00007FFBF02F0000 3.7.7150.1013 unicodedata.pyd
0x00007FFC05970000 sketchup.cp37-win_amd64.pyd
0x00007FFBEE620000 20.1.229.0 SketchUpAPI.dll
0x00007FFBF0270000 20.1.229.63 SketchUpCommonPreferences.dll
0x00007FFC845A0000 10.0.19041.746 DNSAPI.dll
0x00007FFC84560000 10.0.19041.546 IPHLPAPI.DLL
0x00007FFC86490000 10.0.19041.610 NSI.dll
0x00007FFC7B8D0000 10.0.19041.844 fwpuclnt.dll
0x00007FFC7AEA0000 10.0.19041.546 rasadhlp.dll
0x00007FFBE85A0000 pyluxcore.pyd
0x00007FFC067A0000 14.26.28720.3 VCOMP140.DLL
0x00007FFBE2D80000 OpenImageIO_LuxCore.dll
0x00007FFBE39F0000 1.2.1.0 OpenImageDenoise.dll
0x00007FFBE64B0000 3.8.0.0 embree3.dll
0x00007FFBF0100000 2.2.8.0 OpenCL.dll
0x00007FFC76970000 27.21.14.6140 nvcuda.dll
0x00007FFC62C20000 27.21.14.6140 nvcuda64.dll
0x00007FFBE1DF0000 6.14.11.9000 nvrtc64_101_0.dll
0x00007FFC6CE90000 27.21.14.6140 nvapi64.dll
0x00007FFBD8680000 7.3.0.0 nvoptix.dll
0x00007FFBD7480000 27.21.14.6140 nvopencl64.dll
0x00007FFC7C050000 10.0.19041.844 drvstore.dll
0x00007FFBD38D0000 27.21.14.6140 nvrtum64.dll
0x00007FFBF0060000 8.17.14.6140 nvml.dll
0x00007FFBEDEC0000 8.17.14.6140 nvml.dll
0x00007FFBD30B0000 27.21.14.6140 nvptxJitCompiler64.dll
# Python backtrace
If you know how to start programs from the command line in windows, you can go to the directory where the "blender.exe" file is and type "blender -d" and hit ENTER. But if you are not familiar with starting programs from the command line, it will be too complicated.hilth wrote: Thu Apr 15, 2021 2:40 pmI don't even know what that means. heheAndreasResch wrote: Thu Apr 15, 2021 1:19 pm Have you tried starting Blender in debug mode with "blender -d"? Maybe the console window gives some insight into the issue.
Not sure what you mean.Dade wrote: Thu Apr 15, 2021 4:11 pm Are you try to periodically save the film or something similar ? You seem to try to serialize a Film but it can happen only if you have enabled some kind of periodic saving. It is very strange.
# backtrace
Exception Record:
Exception Address : 0x00007FF83EB8D759
Parameters[1] : 0x0000003E829FF3A8
Parameters[2] : 0x00007FFFB3924E58
Parameters[3] : 0x00007FFFB2C60000
Stack trace:
KERNELBASE.dll :0x00007FF83EB8D6F0 RaiseException
VCRUNTIME140.dll :0x00007FF82D636180 CxxThrowException
pyluxcore.pyd :0x00007FFFB2DAC5A0 boost::serialization::void_cast_register<slg::MistPlugin,slg::ImagePipelinePlugin>
pyluxcore.pyd :0x00007FFFB2FC8250 PyInit_pyluxcore
pyluxcore.pyd :0x00007FFFB2DD9170 boost::archive::detail::pointer_oserializer<boost::archive::binary_oarchive,luxrays::SpectrumGroup>
ucrtbase.dll :0x00007FF83E881B20 configthreadlocale
KERNEL32.DLL :0x00007FF8403C7020 BaseThreadInitThunk
ntdll.dll :0x00007FF840F82630 RtlUserThreadStart
Threads:
Thread : 00004d4c
ntdll.dll :0x00007FF840FCCC80 ZwWaitForSingleObject
KERNELBASE.dll :0x00007FF83EB7A2C0 WaitForSingleObjectEx
python37.dll :0x00007FFFBA29D500 Py_HashRandomization_Fini
python37.dll :0x00007FFFBA29DFB0 PyEval_RestoreThread
python37.dll :0x00007FFFBA2E06D0 PyGILState_Ensure
blender.exe :0x00007FF7C6AFB560 bpy_context_set
blender.exe :0x00007FF7C6B04C40 bpy_class_call
blender.exe :0x00007FF7C6A8B830 header_draw
blender.exe :0x00007FF7C6B2C9A0 ED_region_header_layout
blender.exe :0x00007FF7C6B2C0C0 ED_region_do_layout
blender.exe :0x00007FF7C66CBBF0 wm_draw_window_offscreen
blender.exe :0x00007FF7C66CBA40 wm_draw_window
blender.exe :0x00007FF7C66CB540 wm_draw_update
blender.exe :0x00007FF7C66A84D0 WM_main
blender.exe :0x00007FF7C6399C70 main
blender.exe :0x00007FF7CA8A3468 __scrt_common_main_seh
Thread : 00000bb4
blender.exe :0x00007FF7C9EA01D0 IlmThread_2_4::Semaphore::wait
blender.exe :0x00007FF7C9E9F9A0 IlmThread_2_4::ThreadPool::numThreads
blender.exe :0x00007FF7C9EA0650 std::_LaunchPad<std::unique_ptr<std::tuple<void (__cdecl IlmThread_2_4::Thread::*)(void) __ptr64,Il
blender.exe :0x00007FF7C90959C0 std::_Pad::_Call_func
Thread : 0000061c
Thread : 00002628
Thread : 00003b68
Thread : 000043fc
Thread : 00004b64
Thread : 00004474
Thread : 00002a44
Thread : 00004864
ntdll.dll :0x00007FF840FD05F0 ZwWaitForAlertByThreadId
ntdll.dll :0x00007FF840F93EF0 RtlSleepConditionVariableSRW
KERNELBASE.dll :0x00007FF83EBCBA60 SleepConditionVariableSRW
MSVCP140.dll :0x00007FF82A5BBA70 _crtSetThreadpoolWait
MSVCP140.dll :0x00007FF82A592650 std::_Winerror_message
OpenAL32.dll :0x00007FFFCB5A5670 alcGetInteger64vSOFT
OpenAL32.dll :0x00007FFFCB590080 alGetError
Thread : 000010f4
Thread : 00000c80
Thread : 00000808
ntdll.dll :0x00007FF840FD0650 NtWaitForWorkViaWorkerFactory
ntdll.dll :0x00007FF840F82680 TpReleaseCleanupGroupMembers
Thread : 00004d24
nvoglv64.dll :0x00007FFFB5D60310 DrvValidateVersion
nvoglv64.dll :0x00007FFFB5AED59D Symbols not available
Thread : 00000c70
ntdll.dll :0x00007FF840FCD750 NtWaitForMultipleObjects
KERNELBASE.dll :0x00007FF83EBB0C50 WaitForMultipleObjectsEx
KERNELBASE.dll :0x00007FF83EBB0C30 WaitForMultipleObjects
nvoglv64.dll :0x00007FFFB5D996B0 DrvPresentBuffers
nvoglv64.dll :0x00007FFFB61B5920 vk_icdNegotiateLoaderICDInterfaceVersion
Thread : 00002cd4
win32u.dll :0x00007FF83E78A0F0 NtUserMsgWaitForMultipleObjectsEx
USER32.dll :0x00007FF8401706F0 MsgWaitForMultipleObjectsEx
Thread : 00002e8c
Wacom_Tablet.dll :0x00007FF810CE8FE9 WTOpenW
Thread : 000003a4
tbb.dll :0x00007FF82D7E19C0 tbb::thread_bound_filter::try_process_item
Thread : 00002064
Thread : 000045f0
Thread : 00000430
Thread : 00003730
mswsock.dll :0x00007FF83DE680FC Symbols not available
Thread : 00004624
ntdll.dll :0x00007FF840FCD280 NtDelayExecution
KERNELBASE.dll :0x00007FF83EBAD7B0 SleepEx
python37.dll :0x00007FFFBA188B60 PyTraceMalloc_GetTraceback
python37.dll :0x00007FFFBA1D6EE0 PyMethodDef_RawFastCallKeywords
python37.dll :0x00007FFFBA2A3FA0 PyEval_GetFuncDesc
python37.dll :0x00007FFFBA29E490 PyEval_EvalFrameDefault
python37.dll :0x00007FFFBA1D64E0 PyObject_Call
python37.dll :0x00007FFFBA1D69C0 PyFunction_FastCallKeywords
python37.dll :0x00007FFFBA1D7730 PyObject_Call_Prepend
python37.dll :0x00007FFFBA182BA0 PyOS_SigintEvent
python37.dll :0x00007FFFBA309690 PyThread_init_thread
Thread : 00002db8
Thread : 000037e8
Thread : 00003fdc
Thread : 000049cc
Thread : 00004780
pyluxcore.pyd :0x00007FFFB2D8F540 boost::archive::detail::oserializer<boost::archive::binary_oarchive,slg::ImagePipeline>::save_objec
pyluxcore.pyd :0x00007FFFB2C77CA0 boost::serialization::singleton_module::is_locked
pyluxcore.pyd :0x00007FFFB2F98F20 boost::serialization::singleton<boost::archive::detail::extra_detail::map<boost::archive::binary_oa
python37.dll :0x00007FFFBA1D62F0 PyObject_FastCallKeywords
blender.exe :0x00007FF7C6AEC3F0 engine_render
blender.exe :0x00007FF7C9E2BBD0 engine_render_view_layer
blender.exe :0x00007FF7C9E2B2E0 RE_engine_render
blender.exe :0x00007FF7C9E33FE0 do_render
blender.exe :0x00007FF7C9E34200 do_render_composite
blender.exe :0x00007FF7C9E34050 do_render_all_options
blender.exe :0x00007FF7C9E318B0 RE_RenderFrame
blender.exe :0x00007FF7C73D1B80 render_startjob
blender.exe :0x00007FF7C66CD7D0 do_job_thread
blender.exe :0x00007FF7CA8DF320 _ptw32_threadStart
Thread : 000019d8
VCOMP140.DLL :0x00007FF812BA2554 vcomp_ordered_loop_end
VCOMP140.DLL :0x00007FF812BA7FB0 vcomp_atomic_div_r8
Thread : 00001d38
Thread : 000047fc
Thread : 00001ce4
Thread : 0000473c
Thread : 00003570
Thread : 0000161c
Thread : 000030b0
nvcuda64.dll :0x00007FF813B968E4 Symbols not available
Thread : 00004e4c
nvcuda64.dll :0x00007FF813C01090 cuProfilerStop
nvcuda64.dll :0x00007FF813B962B3 Symbols not available
Thread : 00003a9c
ntdll.dll :0x00007FF840F94190 RtlSleepConditionVariableCS
KERNELBASE.dll :0x00007FF83EBCB9B0 SleepConditionVariableCS
nvcuda64.dll :0x00007FF813B14D1C Symbols not available
Thread : 00003ccc
VCRUNTIME140.dll :0x00007FF82D635560 _CxxUnregisterExceptionObject
Thread : 000022c0
Thread : 00002df8
Thread : 00001204
:0x000001746213EC20 Symbols not available
Thread : 00002ac0
Thread : 00001f28
Thread : 00000780
Thread : 00004470
pyluxcore.pyd :0x00007FFFB2DBA410 boost::archive::detail::pointer_oserializer<boost::archive::binary_oarchive,slg::RadianceChannelSca
:0x3FC2F0FD3FC2F0FD Symbols not available
Loaded Modules :
0x00007FF7C6270000 2.9.2.0 blender.exe C:\Program Files\Blender Foundation\Blender 2.92\blender.pdb
0x00007FF840F30000 10.0.19041.844 ntdll.dll
0x00007FF8403B0000 10.0.19041.804 KERNEL32.DLL
0x00007FF83EB60000 10.0.19041.804 KERNELBASE.dll
0x00007FF840150000 10.0.19041.746 USER32.dll
0x00007FF83E780000 10.0.19041.867 win32u.dll
0x00007FF83FD10000 10.0.19041.746 GDI32.dll
0x00007FF83EA50000 10.0.19041.746 gdi32full.dll
0x00007FF83E960000 10.0.19041.789 msvcp_win.dll
0x00007FF83E860000 10.0.19041.789 ucrtbase.dll
0x00007FF82D7D0000 2019.9.0.0 tbb.dll
0x00007FF83EF90000 10.0.19041.844 SHELL32.dll
0x00007FF83EA00000 10.0.19041.546 CFGMGR32.dll
0x00007FF840470000 10.0.19041.546 WS2_32.dll
0x00007FFFBA550000 7.0.0.0 openvdb.dll
0x00007FF840020000 10.0.19041.746 RPCRT4.dll
0x00007FF829AC0000 10.0.19041.844 OPENGL32.dll
0x00007FFFBA0D0000 3.7.7150.1013 python37.dll
0x00007FF840AA0000 7.0.19041.546 msvcrt.dll
0x00007FF840300000 10.0.19041.610 ADVAPI32.dll
0x00007FF83F7C0000 10.0.19041.844 combase.dll
0x00007FF83FE30000 10.0.19041.789 sechost.dll
0x00007FF8404E0000 10.0.19041.746 SHLWAPI.dll
0x00007FF83FB20000 10.0.19041.746 ole32.dll
0x00007FF83FD70000 10.0.19041.546 PSAPI.DLL
0x00007FF83FD40000 10.0.19041.546 IMM32.dll
0x00007FFFB7A90000 58.29.100.0 avformat-58.dll
0x00007FF82D7A0000 58.8.100.0 avdevice-58.dll
0x00007FF83F6E0000 10.0.19041.804 OLEAUT32.dll
0x00007FFFB7DD0000 58.54.100.0 avcodec-58.dll
0x00007FFFF5DA0000 56.31.100.0 avutil-56.dll
0x00007FF82D4C0000 5.5.100.0 swscale-5.dll
0x00007FF83E750000 10.0.19041.662 bcrypt.dll
0x00007FFFCB580000 1.20.1.0 OpenAL32.dll
0x00007FFFCE4B0000 2.0.12.0 SDL2.dll
0x00007FF839910000 2019.9.0.0 tbbmalloc_proxy.dll
0x00007FF8405D0000 10.0.19041.844 SETUPAPI.dll
0x00007FF82A580000 14.26.28720.3 MSVCP140.dll
0x00007FF82D630000 14.26.28720.3 VCRUNTIME140.dll
0x00007FF8365C0000 14.26.28720.3 VCRUNTIME140_1.dll
0x00007FF82D600000 10.0.19041.1 AVIFIL32.dll
0x00007FF820FA0000 6.10.19041.844 COMCTL32.dll
0x00007FF836F20000 10.0.19041.546 VERSION.dll
0x00007FF82AAA0000 10.0.19041.844 GLU32.dll
0x00007FF83CD60000 10.0.19041.867 dbghelp.dll
0x00007FF82ED30000 10.0.19041.546 Secur32.dll
0x00007FF82A550000 3.5.100.0 swresample-3.dll
0x00007FF82D5E0000 10.0.19041.1 AVICAP32.dll
0x00007FF82C690000 10.0.19041.546 WINMM.dll
0x00007FF82A0D0000 2019.9.0.0 tbbmalloc.dll
0x00007FF82A0A0000 10.0.19041.1 MSVFW32.dll
0x00007FF834E30000 10.0.19041.1 MSACM32.dll
0x00007FF81F0C0000 10.0.19041.1 winmmbase.dll
0x00007FF83E530000 10.0.19041.662 SSPICLI.DLL
0x00007FF83FF70000 10.0.19041.746 shcore.dll
0x00007FF83CFA0000 10.0.19041.546 kernel.appcore.dll
0x00007FF83C500000 10.0.19041.844 windows.storage.dll
0x00007FF83E0E0000 10.0.19041.662 Wldp.dll
0x00007FF83BE60000 10.0.19041.746 uxtheme.dll
0x00007FF83E670000 10.0.19041.662 bcryptPrimitives.dll
0x00007FF83E5B0000 10.0.19041.844 profapi.dll
0x00007FF83FD80000 2001.12.10941.16384 clbcatq.dll
0x00007FF8387C0000 10.0.19041.789 MMDevApi.dll
0x00007FF83E420000 10.0.19041.546 DEVOBJ.dll
0x00007FF838B30000 10.0.19041.789 AUDIOSES.DLL
0x00007FF83DE10000 10.0.19041.546 powrprof.dll
0x00007FF83DD40000 UMPDC.dll
0x00007FF83BF20000 10.0.19041.546 resourcepolicyclient.dll
0x00007FF840C20000 10.0.19041.867 MSCTF.dll
0x00007FF81E780000 10.0.19041.746 dataexchange.dll
0x00007FF83ABA0000 10.0.19041.746 d3d11.dll
0x00007FF83B0F0000 10.0.19041.746 dcomp.dll
0x00007FF83CFC0000 10.0.19041.746 dxgi.dll
0x00007FF837000000 10.0.19041.746 twinapi.appcore.dll
0x00007FF838650000 10.0.19041.844 AppXDeploymentClient.dll
0x00007FFFB50F0000 27.21.14.6231 nvoglv64.dll
0x00007FF83A160000 10.0.19041.546 WTSAPI32.dll
0x00007FF83E260000 10.0.19041.546 msasn1.dll
0x00007FF836E70000 10.0.19041.546 cryptnet.dll
0x00007FF83EE30000 10.0.19041.844 CRYPT32.dll
0x00007FF83E050000 10.0.19041.546 cryptbase.dll
0x00007FF83E6F0000 10.0.19041.804 WINTRUST.dll
0x00007FF83D3C0000 10.0.19041.546 ntmarta.dll
0x00007FF82CC00000 10.0.19041.546 dxcore.dll
0x00007FF83C140000 10.0.19041.746 dwmapi.dll
0x00007FF83DA80000 10.0.19041.546 WINSTA.dll
0x00007FF82F140000 10.0.19041.844 textinputframework.dll
0x00007FF83B6A0000 10.0.19041.546 CoreUIComponents.dll
0x00007FF83BB50000 10.0.19041.746 CoreMessaging.dll
0x00007FF83AF90000 10.0.19041.844 wintypes.dll
0x00007FFFB9E80000 1.0.5.10 Wintab32.dll
0x00007FF82F980000 10.0.19041.546 MPR.dll
0x00007FF810CE0000 6.3.42.2 Wacom_Tablet.dll
0x00007FF819EB0000 10.0.19041.844 explorerframe.dll
0x00007FF839D70000 7.0.19041.867 propsys.dll
0x00007FF83E030000 10.0.19041.546 CRYPTSP.dll
0x00007FF83D730000 10.0.19041.546 rsaenh.dll
0x00007FF836530000 3.7.7150.1013 python3.dll
0x00007FFFB4E20000 _multiarray_umath.cp37-win_amd64.pyd
0x00007FF82D4A0000 _multiarray_tests.cp37-win_amd64.pyd
0x00007FF829550000 3.7.7150.1013 _ctypes.pyd
0x00007FF81A210000 lapack_lite.cp37-win_amd64.pyd
0x00007FFFB4C00000 _umath_linalg.cp37-win_amd64.pyd
0x00007FF82AA80000 3.7.7150.1013 _bz2.pyd
0x00007FF81ED20000 3.7.7150.1013 _lzma.pyd
0x00007FF81DA90000 3.7.7150.1013 _decimal.pyd
0x00007FF829D10000 _pocketfft_internal.cp37-win_amd64.pyd
0x00007FFFCD1C0000 mtrand.cp37-win_amd64.pyd
0x00007FF81CF80000 common.cp37-win_amd64.pyd
0x00007FF811CE0000 bounded_integers.cp37-win_amd64.pyd
0x00007FF81FD80000 mt19937.cp37-win_amd64.pyd
0x00007FF81CF50000 bit_generator.cp37-win_amd64.pyd
0x00007FF833CD0000 3.7.7150.1013 _hashlib.pyd
0x00007FFFB48B0000 1.1.1.4 libcrypto-1_1.dll
0x00007FF81D9C0000 philox.cp37-win_amd64.pyd
0x00007FF81CEE0000 pcg64.cp37-win_amd64.pyd
0x00007FF81CE90000 sfc64.cp37-win_amd64.pyd
0x00007FFFCCE90000 generator.cp37-win_amd64.pyd
0x00007FFFB44B0000 etree.cp37-win_amd64.pyd
0x00007FF81B2F0000 _elementpath.cp37-win_amd64.pyd
0x00007FF81A1F0000 3.7.7150.1013 _socket.pyd
0x00007FF830590000 3.7.7150.1013 select.pyd
0x00007FF81A100000 3.7.7150.1013 _ssl.pyd
0x00007FFFC2410000 1.1.1.4 libssl-1_1.dll
0x00007FF82D850000 3.7.7150.1013 _queue.pyd
0x00007FF83DE60000 10.0.19041.546 mswsock.dll
0x00007FFFC1EB0000 3.7.7150.1013 unicodedata.pyd
0x00007FFFF5A50000 sketchup.cp37-win_amd64.pyd
0x00007FFFB3BD0000 20.1.229.0 SketchUpAPI.dll
0x00007FFFCCE10000 20.1.229.63 SketchUpCommonPreferences.dll
0x00007FF83DB20000 10.0.19041.746 DNSAPI.dll
0x00007FF83DAE0000 10.0.19041.546 IPHLPAPI.DLL
0x00007FF8402F0000 10.0.19041.610 NSI.dll
0x00007FF834EA0000 10.0.19041.844 fwpuclnt.dll
0x00007FF834E10000 10.0.19041.546 rasadhlp.dll
0x00007FFFB2C60000 pyluxcore.pyd
0x00007FF812BA0000 14.26.28720.3 VCOMP140.DLL
0x00007FFFAD440000 OpenImageIO_LuxCore.dll
0x00007FFFB01A0000 1.2.1.0 OpenImageDenoise.dll
0x00007FFFAE0B0000 3.8.0.0 embree3.dll
0x00007FFFC0C20000 2.2.8.0 OpenCL.dll
0x00007FF82BF60000 27.21.14.6231 nvcuda.dll
0x00007FF8139E0000 27.21.14.6231 nvcuda64.dll
0x00007FFFAC4B0000 6.14.11.9000 nvrtc64_101_0.dll
0x00007FF831D20000 27.21.14.6231 nvapi64.dll
0x00007FFF9F620000 7.3.0.0 nvoptix.dll
0x00007FFFAB2B0000 27.21.14.6231 nvopencl64.dll
0x00007FF81DF80000 10.0.19041.844 drvstore.dll
0x00007FFF9BA70000 27.21.14.6231 nvrtum64.dll
0x00007FFFCCA60000 8.17.14.6231 nvml.dll
0x00007FFFAAEC0000 8.17.14.6231 nvml.dll
0x00007FFFA97A0000 27.21.14.6231 nvptxJitCompiler64.dll
# Python backtrace
Dade wrote: Wed Apr 14, 2021 9:15 pmThe problem is here. Look for your libnvrtc-builtins.so inside "/home/XXX/.config/blender/2.92/scripts/addons/BlendLuxCore/bin" directory, check if the file is there and it has the "x" bit set (the execution bit).mroy wrote: Wed Apr 14, 2021 6:30 pm nvrtc: error: failed to open libnvrtc-builtins.so.
Make sure that libnvrtc-builtins.so is installed correctly.
I doubt that this is related to hilth's problem because he is working on Windows while your problem is Linux related.
ls -l ~/.config/blender/2.92/scripts/addons/BlendLuxCore/bin
total 224480
-rw-r--r-- 1 mroy mroy 0 Apr 9 10:58 __init__.py
drwxr-xr-x 2 mroy mroy 72 Apr 10 10:02 __pycache__
-rw-r--r-- 1 mroy mroy 2873 Apr 9 10:58 get_binaries.py
-rwxr-xr-x 1 mroy mroy 48414768 Apr 9 10:58 libOpenImageDenoise.so.0
-rwxr-xr-x 1 mroy mroy 47079560 Apr 9 10:58 libembree3.so.3
-rwxr-xr-x 1 mroy mroy 5457072 Apr 9 10:58 libnvrtc-builtins.so
-rwxr-xr-x 1 mroy mroy 5457072 Apr 9 10:58 libnvrtc-builtins.so.11.0
-rwxr-xr-x 1 mroy mroy 5457072 Apr 9 10:58 libnvrtc-builtins.so.11.0.194
-rwxr-xr-x 1 mroy mroy 22293896 Apr 9 10:58 libnvrtc.so
-rwxr-xr-x 1 mroy mroy 22293896 Apr 9 10:58 libnvrtc.so.11.0
-rwxr-xr-x 1 mroy mroy 22293896 Apr 9 10:58 libnvrtc.so.11.0.194
-rwxr-xr-x 1 mroy mroy 2209272 Apr 9 10:58 libtbb.so.2
-rwxr-xr-x 1 mroy mroy 790496 Apr 9 10:58 libtbbmalloc.so.2
-rwxr-xr-x 1 mroy mroy 148408 Apr 9 10:58 oidnDenoise
-rwxr-xr-x 1 mroy mroy 47877720 Apr 9 10:58 pyluxcore.so
-rw-r--r-- 1 mroy mroy 58825 Apr 9 10:58 pyluxcoretools.zip
-rw-r--r-- 1 mroy mroy 675 Apr 9 10:58 readme.mdSorry, I'll do that next time. :\B.Y.O.B. wrote: Thu Apr 15, 2021 6:36 pm You can also attach the log as a text file, it seems too long for a post.
Try to do a:mroy wrote: Thu Apr 15, 2021 6:49 pmDade wrote: Wed Apr 14, 2021 9:15 pmThe problem is here. Look for your libnvrtc-builtins.so inside "/home/XXX/.config/blender/2.92/scripts/addons/BlendLuxCore/bin" directory, check if the file is there and it has the "x" bit set (the execution bit).mroy wrote: Wed Apr 14, 2021 6:30 pm nvrtc: error: failed to open libnvrtc-builtins.so.
I doubt that this is related to hilth's problem because he is working on Windows while your problem is Linux related.Code: Select all
ls -l ~/.config/blender/2.92/scripts/addons/BlendLuxCore/bin total 224480 -rw-r--r-- 1 mroy mroy 0 Apr 9 10:58 __init__.py drwxr-xr-x 2 mroy mroy 72 Apr 10 10:02 __pycache__ -rw-r--r-- 1 mroy mroy 2873 Apr 9 10:58 get_binaries.py -rwxr-xr-x 1 mroy mroy 48414768 Apr 9 10:58 libOpenImageDenoise.so.0 -rwxr-xr-x 1 mroy mroy 47079560 Apr 9 10:58 libembree3.so.3 -rwxr-xr-x 1 mroy mroy 5457072 Apr 9 10:58 libnvrtc-builtins.so -rwxr-xr-x 1 mroy mroy 5457072 Apr 9 10:58 libnvrtc-builtins.so.11.0 -rwxr-xr-x 1 mroy mroy 5457072 Apr 9 10:58 libnvrtc-builtins.so.11.0.194 -rwxr-xr-x 1 mroy mroy 22293896 Apr 9 10:58 libnvrtc.so -rwxr-xr-x 1 mroy mroy 22293896 Apr 9 10:58 libnvrtc.so.11.0 -rwxr-xr-x 1 mroy mroy 22293896 Apr 9 10:58 libnvrtc.so.11.0.194 -rwxr-xr-x 1 mroy mroy 2209272 Apr 9 10:58 libtbb.so.2 -rwxr-xr-x 1 mroy mroy 790496 Apr 9 10:58 libtbbmalloc.so.2 -rwxr-xr-x 1 mroy mroy 148408 Apr 9 10:58 oidnDenoise -rwxr-xr-x 1 mroy mroy 47877720 Apr 9 10:58 pyluxcore.so -rw-r--r-- 1 mroy mroy 58825 Apr 9 10:58 pyluxcoretools.zip -rw-r--r-- 1 mroy mroy 675 Apr 9 10:58 readme.md
ldd libnvrtc.so
