Page 2 of 2
Re: bad lexical cast on export from blender
Posted: Fri May 11, 2018 9:47 am
nocivo wrote: Fri May 11, 2018 1:46 am
no ",". The output is the same of your. But the cornell scene is the only scene that start without error.
Have cloned the
https://github.com/LuxCoreRender/LuxCore repository and other scenes do not work ? If you try:
luxcoreui scenes/luxball/luxball.cfg
Does it work ?
Posted: Sat May 12, 2018 3:09 am
by nocivo
Hi Dade,
the scenes on github work well. The scenes exported using my blender installation, don't work.
Now I will try to reinstall blender using a clean installation. I will try also on windows to see if there is the same issue.
On linux, only me have this issue?
Thanks for your support
Posted: Sat May 12, 2018 11:43 am
nocivo wrote: Sat May 12, 2018 3:09 am
There have been a couple of issues reported by Russian users (i.e. a radically different locale settings from western locales) and Linux but they ended to be related to some specific setting of their system, for instance, try to check this post and the solution described there:
viewtopic.php?f=4&t=223&p=2854&hilit=locale#p2894
I have the feeling there is a problem with radically different locales like Russian and Japanese but we have not yet found the "smoking gun" proof (and solution).
As you have seen, LuxCore alone works fine, there may be some setting affecting LuxCore when running inside Blender.
Posted: Mon May 14, 2018 6:31 am
by nocivo
thanks Dade,
I solved by un-selecting the international fonts in blender, remove luxcore addon, restart blender and install again luxcore addon.
Before, I used the international fonts options with language setting on english, but I have activated it to read materials and objects name writed in other language like japanese. Now, with international fonts option disabled, I cannot read object and material name wrote with character different from Latin. If you will solve this it's better, but I don't know if it is a luxcore or blender bug.
thanks
Posted: Mon May 14, 2018 8:54 am
nocivo wrote: Mon May 14, 2018 6:31 am
The source of the problem is how locale is handled by C/C++ in general: it is a global setting so a change in Blender will affect LuxCore too. The reverse it also true: so I can not change the setting inside LuxCore or it would affect and break Blender.
It is also a problem hard to investigate for me because I'm from western country without a non-latin locale (i.e. Russian, Japanese, Chinese, etc.). I'm afraid will leave it as a known bug until someone pop up with a solution.
Posted: Fri Aug 27, 2021 10:10 pm
by BBIWY
Hello @ all,
i found a nasty workaround for this.
I'm on Ubuntu 14.04 64 bit and use Blender 2.79b 64bit and BlendLuxCore 2.2 and LuxCore 2.2.
After exporting the project as "text" (render.cfg) i do this:
1. start luxcoreui with
2. load the
file and start rendering
3. pause the rendering and save the rendering as 1.rsm
4. rename 1.rsm to 1.gz
5. then i do a
6. now i open the extracted file:
7. then i substitute the relevant "," with "." and save the file
8. then
9. and at last
/path/to/./luxcoreui -o /tmp/Untitled_LuxCore/00001/1.rsm -w 1920 -e 1080
it works for me!
Posted: Sat Aug 28, 2021 12:12 am
BBIWY wrote: Fri Aug 27, 2021 10:10 pm
You are using a very old version of LuxCore (and Ubuntu). This type of problems should have been addressed in the latest version (but they may not work on your old Ubuntu).
Posted: Sat Aug 28, 2021 7:30 pm
by BBIWY
I know this topic, my OS and (Blend)LuxCore versions are old. My Computer is old and because of glibc newer (Blend)LuxCore versions don't work anymore, and the Blender version has to be compatible. Just wanted to help someone who ran into the same problem, cause i read about people having the same problem with newer (Blend)LuxCore versions. And this program is nonsense without the possibility to resume rendering. I wonder why this thread isn't closed or marked as solved.
Btw how can i delete my account, if i want to? Found no option for that!
Greetings
Posted: Sat Aug 28, 2021 9:34 pm
BBIWY wrote: Sat Aug 28, 2021 7:30 pm
Uh ? Not sure, the forum software is a plain phpBB:
https://www.phpbb.com/
