Page 2 of 2
Re: Yellow Chairs
Posted: Wed May 09, 2018 5:39 pm
zezic, did you note down the times in your material brightness test?
I compared images at equal render time, while you compared them at equal samples per pixel count.
Just a comment, I don't intend to sidetrack this into a testing thread
Re: Yellow Chairs
Posted: Wed May 09, 2018 10:30 pm
by zezic
B.Y.O.B. wrote: Wed May 09, 2018 5:39 pm
Hmm, I don't remember times, but I'll do more tests later and check this.
Re: Yellow Chairs
Posted: Sat May 12, 2018 10:22 am
by Racleborg
Hi Zezic
I've just noticed that there is no BUMP node being used on the floor. The Image map is being connected directly into the the Glossy material BUMP socket?
Re: Yellow Chairs
Posted: Tue May 15, 2018 12:52 pm
by zezic
Racleborg wrote: Sat May 12, 2018 10:22 am
Yes, and image map brightness decreased. Is Bump node necessary?
Re: Yellow Chairs
Posted: Tue May 15, 2018 3:33 pm
zezic wrote: Tue May 15, 2018 12:52 pm
No. If you look at the code, it is just a scale texture (aka multiply):
https://github.com/LuxCoreRender/BlendL ... ump.py#L15
Re: Yellow Chairs
Posted: Tue May 15, 2018 5:29 pm
by Racleborg
That's makes a clean work flow!
Thanks
Re: Yellow Chairs
Posted: Sun Jul 15, 2018 12:46 pm
by Luxart
These are rendered with Luxcore 2.1 alpha (with denoiser).
The render times are around 4 - 5 mins (CPU i74770K, GPU R9280x).
After denoiser the Luxcore speed jumps multifold. What do you guys think.
Area lights
Distant and area light
infinite and area light
The renders might not be clean. just did a quick test.
Zezic, Thanks for the scene. Useful for quick tests.
