Page 2 of 2
Re: Image Pipeline etc.
Posted: Fri Sep 18, 2020 11:35 am
There's already an issue about this here: https://github.com/LuxCoreRender/LuxCore/issues/448
Posted: Fri Sep 18, 2020 11:55 am
B.Y.O.B. wrote: Fri Sep 18, 2020 11:35 am There's already an issue about this here: https://github.com/LuxCoreRender/LuxCore/issues/448
See my answer there.
Posted: Fri Sep 18, 2020 1:57 pm
by marcatore
It's working fine now.
Thank you!!
Posted: Mon Sep 21, 2020 11:23 am
Posted: Mon Sep 21, 2020 11:32 am
by marcatore
Good..really good.
I've a question about the "reverse" option.
Is it there due to a compatibility or another reason?
I'm asking this cause I can't understand how a white balancing system could work differently from this "reverse" way.
I mean...as I know...a white balance in photography is always to add a filter (through light or camera setting) that counterbalance the temperature of the light (s) that enlight the scene.
in my opinion the "old" way Luxcore did the white balance, so, in my opinion it will be difficult to find someone that used that.
So, this "reverse" way should be the "normal" behaviour with any kind of settings...eventually it should be added a "legacy" option always turned off.
I know that now the "reverse" mode is always on by default but it sounds like an additional option that could confusing the new user.
Posted: Mon Sep 21, 2020 10:35 pm
marcatore wrote: Mon Sep 21, 2020 11:32 am I've a question about the "reverse" option.
Mostly to not break the compatibility with the past.
Posted: Tue Sep 22, 2020 6:49 am
by marcatore
clear.
But I'm quite sure that anyone used it cause it was just wrong.
I'd like to read something by the other users.
Probably this could be workarounded by the Blender addon...but in my opinion is adding complexity "for nothing".
