Page 2 of 2
Re: World light always from the left?
Posted: Sat Apr 14, 2018 12:05 pm
Racleborg wrote: Sat Apr 14, 2018 11:36 am
So is this setup incorrect and that the gamma should be set to 2.2? (file attached)
Nope, you need to not use gamma correction (i.e. gamma = 1.0) so the screenshot is right.
Posted: Sat Apr 14, 2018 12:11 pm
Should I just hide the gamma setting in normalmap mode and set gamma = 1.0 behind the scenes in the addon?
Posted: Sat Apr 14, 2018 12:31 pm
by Racleborg
Dade. Thanks for the confirmation
BYOB. Thanks, I think that would be quite helpful to us that are a bit new to it all.
Cheers
Posted: Sat Apr 14, 2018 12:52 pm
Done.
I also fixed some other stuff that was wrong with normalmap handling (e.g. the fallback color being [0, 0, 0] instead of [0.5, 0.5, 1.0] when no map was selected).
Posted: Sat Apr 14, 2018 1:00 pm
by Racleborg
Cool.
I would just like to say that as I am hoping to be doing mainly upholstered furniture, the VELVET shader with advanced options is absolutely awesome!
Posted: Sat Apr 14, 2018 8:27 pm
B.Y.O.B. wrote: Sat Apr 14, 2018 12:11 pm
Hmm, i had an idea not so long ago... it would be nice to split the
Imagemap node into two: one only for images/textures/maps and other for transformations. This way we could feed many textures through one transformation or one single texture through few transformations. Would be of help with PBR workflow where
roughness, AO, metallness are stored in channels.
What's the thought on that?
Just please, don't remove the
advanced options.
This is not advanced, but more like common knowledge.
Posted: Sun Apr 15, 2018 7:09 am
kintuX wrote: Sat Apr 14, 2018 8:27 pm
it would be nice to split the Imagemap node into two: one only for images/textures/maps and other for transformations. This way we could feed many textures through one transformation or one single texture through few transformations.
Can you draw me a mockup of what you mean exactly?
I think what you want is already possible (or you mean something else with "transformations" than the UV transformations?).
Posted: Sun Apr 15, 2018 10:35 am
I apologize for not being clear enough.
What i meant was separating (removing)
color transformations from Imagemap (gama, brightness) and putting those into separate node under Utils (as is the case in Cycles with Gamma & Bright/Contrast nodes). While Imagemap node could have all Channels outputs available from single node (as an advanced 'Channels' option). Since there's no Separate/Combine RGB nodes. So for now only one output per Imagemap node is possible.
Again, i apologize for making a mess.
Proposals are stacking up and i believe i should make a proper/separated thread and also register at GitHub already
Have a nice day
