Re: Unified executable (for CPU-only, OpenCL and CUDA)
Posted: Wed May 27, 2020 10:43 pm
Windows never stop to amaze me (a limited stack size in 2020...), I should have fixed the problem in the latest sources.
Defining symbols should be not required any more. Binaries will have now always the potential ability to work with CUDA and OpenCL if the drivers are available when run.
MacBook-Pro:LuxCore drquader$ otool -L build/Release/luxcoreui
build/Release/luxcoreui:
@rpath/libomp.dylib (compatibility version 5.0.0, current version 5.0.0)
/System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa (compatibility version 1.0.0, current version 23.0.0)
/System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL (compatibility version 1.0.0, current version 1.0.0)
/System/Library/Frameworks/IOKit.framework/Versions/A/IOKit (compatibility version 1.0.0, current version 275.0.0)
/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation (compatibility version 150.0.0, current version 1560.12.0)
/System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo (compatibility version 1.2.0, current version 1.5.0)
@rpath/libembree3.3.dylib (compatibility version 3.0.0, current version 3.0.0)
@rpath/libOpenImageDenoise.0.dylib (compatibility version 0.0.0, current version 1.2.0)
@rpath/libtbb.dylib (compatibility version 0.0.0, current version 0.0.0)
@rpath/libtiff.5.dylib (compatibility version 11.0.0, current version 11.0.0)
/usr/lib/libz.1.dylib (compatibility version 1.0.0, current version 1.2.11)
@rpath/libOpenImageIO.1.8.dylib (compatibility version 1.8.0, current version 1.8.13)
/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 400.9.4)
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1252.200.5)
/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit (compatibility version 45.0.0, current version 1671.10.106)
/System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics (compatibility version 64.0.0, current version 1247.4.1)
/System/Library/Frameworks/Foundation.framework/Versions/C/Foundation (compatibility version 300.0.0, current version 1560.12.0)
/usr/lib/libobjc.A.dylib (compatibility version 1.0.0, current version 228.0.0)What is so bad about that ? On Linux you can use NVIDIA and AMD GPU together ... i plan to do that ...acasta69 wrote: Thu May 28, 2020 7:27 pm LuxCoreUI still allows to choose OCL render engines. I'll try to check why this happens.
Well, nothing so bad I guess...u3dreal wrote: Thu May 28, 2020 7:59 pm What is so bad about that ? On Linux you can use NVIDIA and AMD GPU together ... i plan to do that ...
What dlls do you need to copy ??
