Page 2 of 3
Re: Speeding up the viewport preview
Posted: Wed Apr 22, 2020 11:38 am
Dade wrote: Wed Apr 22, 2020 11:27 am
Sharlybg wrote: Wed Apr 22, 2020 11:22 am
are we going to loose something by leaving this RT engine instead of adapt it to be decoupled ?
isn't Rt more optimized for viewport render preview ?
You loose the "zoom in" effect at the start of the rendering (i.e. rendering with large pixel blocks and than refine).
P.S. I can decouple RT too but I will have to use some more memory to store a copy of the image.
Well... I wouldn't miss the pixelated rendering at all! It's useless anyways no?
Posted: Wed Apr 22, 2020 11:50 am
Zoom effect help improve viewport responssivness i assume. How much memory cost will be ? if it is in the same league of cycles memory consumption then it is a win anyway.
It is a muss to have a more responssive viewport as the userbase increase this will become more and more a problem.
Posted: Wed Apr 22, 2020 11:58 am
Sharlybg wrote: Wed Apr 22, 2020 11:50 am
It is an additional copy of the rendered image (including all AOVs, etc.).
Posted: Wed Apr 22, 2020 12:10 pm
Viewport windows are often small, and during viewport render only a few AOVs are used (RGB, alpha if transparent, avg. shading normal and albedo if viewport denoising is enabled).
So I doubt one copy is much of a problem.
Posted: Wed Apr 22, 2020 12:24 pm
It should be easy to add but open a GitHub issue because, at the moment, I have a kilometre long backlog of stuff to look into.
Posted: Wed Apr 22, 2020 12:29 pm
Dade wrote: Wed Apr 22, 2020 12:24 pm
B.Y.O.B. wrote: Wed Apr 22, 2020 12:10 pm
So currently for a fast fix before Dade look into RT modification we can just move to the other engine ( already decoupled one ). so we can just download the last build and see the difference and how it help.
Posted: Wed Apr 22, 2020 12:36 pm
Sharlybg wrote: Wed Apr 22, 2020 12:29 pm
If it is not already possible, just add it like an option, like you can already use BIDIRCPU, etc.
Posted: Wed Apr 22, 2020 12:59 pm
Enabling light tracing should do it, you'll get PathCPU/OCL in that case. (it still uses WaitNewFrame(), but I guess that will return immediately in this case?)
Posted: Wed Apr 22, 2020 1:14 pm
B.Y.O.B. wrote: Wed Apr 22, 2020 12:59 pm
light tracing enable as a viewport engine ? this is not what i will call an improvement.
Posted: Wed Apr 22, 2020 1:34 pm
I'd still say just use non-rt for viewport... A little lag from rendering isnt as bad as lag when changing materials and so on... I can literally leave octane rendering heavy scene and play around with everything even though rendering and changes are behind, there is no problem changing color sliders etc..
