Page 2 of 5
Re: HDRi and Light Tracing
Posted: Thu Apr 09, 2020 9:02 pm
Check the number of native threads you have in OpenCL, it must be > zero. It renders fine here.
Posted: Thu Apr 09, 2020 9:56 pm
by jgrover110
CPU threads are set to auto-detect, which come up as 8 for me.
Posted: Thu Apr 09, 2020 10:39 pm
by CodeHD
I tested it here (win10, Bl2.81, Lux 2.4 daily from ~3 days ago) and it works fine. I downloaded you scene, rendered directly (CPU), switched to OpenCL setting, rendered again.
CPU:
OCL:
EDIT: Looks a lot brighter than your pictures though...
Posted: Thu Apr 09, 2020 10:47 pm
by jgrover110
CodeHD wrote: Thu Apr 09, 2020 10:39 pm
That would be because I use the ACES tonemapping
Posted: Thu Apr 09, 2020 11:02 pm
by jgrover110
Did a fresh install of latest Blendluxcore, same problem.
Posted: Thu Apr 09, 2020 11:09 pm
by CodeHD
How about the OpenCL/GPU drivers? This wasn't mentioned in this thread yet, and dirver problems have occured in the past.
What are you system specs actually?
Posted: Thu Apr 09, 2020 11:18 pm
by jgrover110
Ryzen 5 2400g
Radeon Rx570
Radeon Software 20.2.1
I'll update and test again tomorrow
Posted: Fri Apr 10, 2020 12:22 am
jgrover110 wrote: Thu Apr 09, 2020 11:18 pm
Try to check also your CPU load during the rendering
Posted: Fri Apr 10, 2020 10:58 am
Tested and confirmed - working fine w/o any visual difference in CPU vs OCL rendered images (even when using ACES color management).
Posted: Fri Apr 10, 2020 11:52 am
by jgrover110
Dade wrote: Fri Apr 10, 2020 12:22 am
Updated to 20.4.1, still not correct. CPU load reaches 100% in task manager. This must be hardware specific if other people cannot reproduce it.
