Re: Light group support for PhotonGI?
Posted: Thu Apr 02, 2020 12:09 pm
I was referring to the clamping value in general, having a clamping value per light group it's even better
Are you sure ? I mean, if I can ignore the "additional memory problem" I can easily add the support for light groups (storing 8 x 3 floats values instead of 3 float, max. light group count x RGB instead of 1 x RGB).B.Y.O.B. wrote: Tue Mar 31, 2020 2:21 pm In the hall bench scene, the VRAM usage is:
- without cache: 1029 MiB
- with cache: 1031 MiB
We just need a warning Message on it. Being a special features it is acceptable to have such sacrifice to do. multiple render in one this is awesome.The question is: the memory usage will jump from 2MB to 16MB (and no one care) or it will jump from 100MB to 800MB and people will start to load their guns
No, it is not optional, even if you use a single light group, it will use 16MB instead of 2MB (i.e. no problem) and 800MB instead of 100MB (i.e. big problem).Sharlybg wrote: Fri Apr 03, 2020 1:24 pmWe just need a warning Message on it. Being a special features it is acceptable to have such sacrifice to do. multiple render in one this is awesome.The question is: the memory usage will jump from 2MB to 16MB (and no one care) or it will jump from 100MB to 800MB and people will start to load their guns
understood (This is CrazyNo, it is not optional, even if you use a single light group, it will use 16MB instead of 2MB (i.e. no problem) and 800MB instead of 100MB (i.e. big problem).
Some tests, VRAM usage of PhotonGI indirect light cache (no caustics cache), as reported by LuxCore:Dade wrote: Fri Apr 03, 2020 1:13 pmAre you sure ? I mean, if I can ignore the "additional memory problem" I can easily add the support for light groups (storing 8 x 3 floats values instead of 3 float, max. light group count x RGB instead of 1 x RGB).B.Y.O.B. wrote: Tue Mar 31, 2020 2:21 pm In the hall bench scene, the VRAM usage is:
The question is: the memory usage will jump from 2MB to 16MB (and no one care) or it will jump from 100MB to 800MB and people will start to load their guns![]()
The memory can't be allocated only on demand?Dade wrote: Fri Apr 03, 2020 1:28 pm No, it is not optional, even if you use a single light group, it will use 16MB instead of 2MB (i.e. no problem) and 800MB instead of 100MB (i.e. big problem).
No, if you are reading the numbers from the log, they are correct as far as I know.B.Y.O.B. wrote: Fri Apr 03, 2020 2:40 pm If these numbers look fishy to you, maybe LuxCore is not counting all VRAM usage of PhotonGI?
It is but is more complex (mostly in OpenCL).
That was fast. We still need blendluxcore add to test i guess.Dade wrote: Sat Apr 04, 2020 11:41 am I added the support for light groups to PhotonGI (both indirect and caustic cache)![]()
