This is strange!
Blender and Cycles load both processors.
3dmax vray and the corona load two processors
Keyshot works the same.
Only with Blendluxcore only one processor works
Why does this happen only with blendluxcore?
LuxCoreRender v2.3beta2 released
Re: LuxCoreRender v2.3beta2 released
I guess they have explicit support for Windows processor groups (https://docs.microsoft.com/en-us/window ... sor-groups):BigGoga wrote: Fri Feb 21, 2020 5:49 am This is strange!
Applications for which performance is critical and that can scale efficiently beyond 64 logical processors must be modified to run on such systems. For example, database applications might benefit from modifications.
It turns out that BlendLuxCore is not yet fully optimized for working on systems with a CPU more than 64?
Read the linked article, it is a limit of some Windows version.BigGoga wrote: Fri Feb 21, 2020 12:53 pm It turns out that BlendLuxCore is not yet fully optimized for working on systems with a CPU more than 64?
I read the article.Dade wrote: Fri Feb 21, 2020 1:22 pm Read the linked article, it is a limit of some Windows version.
Why are these restrictions only applied when working with BlendLuxCore?
And do not work in other programs?
It is explained here: viewtopic.php?p=20208#p20184
You can actually tell this is the case. If you try to run LuxCoreRender on Windows Vista it runs just fine, with no problems. If you try to launch Luxrender 1.6 on Windows Vista it shows a "getactive processorcount kernel32.dll" error. The newer feature is supported in Windows Server 2008 and later, but is not part of LuxCoreRender yet.
Calling all Linux users: check out the new LuxRender 1.7 Flatpak! https://github.com/rrubberr/Flatpak-LuxRender
Light transport enthusiast - www.rrubberr.com
@Racleborg as well:Harvester wrote: Mon Feb 17, 2020 5:00 pm I've just downloaded the Latest Build (by Dade [97a03c8]) and the updated update.py file is there but the behavior in the Preferences is still the same: no builds listed in the Release for Change Version, as you can see below:
For some reason I can now reproduce this problem with v2.3beta2.
However, in v2.3rc1 the updater seems to work fine again, can you confirm this?
Hi, I confirm you that v2.3rc1 works perfectly in Blender 2.82 and 2.83 (alpha) as well as the option to change version. I noticed that with this release of BlenderLuxCore add-on only 2.3 versions are listed, the previous versions are no longer available. I presume this is by design. it's fine for me also because I can always recover previous versions of LuxCoreRender if I need them with old versions of Blender. Cheers!
Yes, it's by design, because versions before v2.2 don't support Blender 2.80, and v2.2 uses a different naming scheme for the download files so rather than making the code more complicated, I left it out.Harvester wrote: Wed Mar 04, 2020 1:23 pm I noticed that with this release of BlenderLuxCore add-on only 2.3 versions are listed, the previous versions are no longer available. I presume this is by design.
